K20A2 Mini
Posted 21 December 2013 - 08:12 PM
Posted 21 December 2013 - 08:21 PM
It all depends on how much work you are looking at doing. I am no expert but I'm looking at doing a Honda conversion also but from what I have seen and read, unless you are going to cut and modify the firewall it would require an extended front end. plus mod minis is the UK supplier of all the American 'superfastminis' products. they do the subframe conversion kits and for a k series engine they state you would need an extended front end.
you could make your own subframe but again it all depends on your budget and time.
Posted 21 December 2013 - 08:25 PM
Posted 21 December 2013 - 08:34 PM
Posted 21 December 2013 - 09:26 PM
It all depends on what you are going to do with the subframe really. Are you buying one or planning on making one?
I think also that the reason why 'superfastminis' made there conversion frame Llonger is to accommodate the gearbox as I think it's larger that the b (I may be wrong on that) there is a guy on here that started a k series conversion but he hasn't updated the thread for a long time so you may have to search for it but he was making his own subframe because he wanted it to fit under a standard round nose. He also cut the fire wall to make it work.
You may also find that if you went down the route of trying to fit it under a standard round nose and was prepared to make a subframe you would struggle with room for a radiator. It's really tight to fit a radiator with a b series engine so it would be a lot harder with a k series engine.
Posted 21 December 2013 - 09:33 PM
Posted 21 December 2013 - 10:28 PM
Posted 22 December 2013 - 02:49 PM
If in doubt of anything just ask and I'm sure one of us on here can help you out.
Keep the thread active with progress Aswell, I would love to see how you get on with it. May even make me do a 4wd k series Honda.
Posted 22 December 2013 - 02:51 PM
Posted 22 December 2013 - 03:03 PM
Posted 23 January 2014 - 08:19 PM
I'm afraid that I should just forget about the roundnose. If I move the firewall I need to replace the pedals and then the steer should also be repositioned.
Hi there, I am also looking to do the K20 conversion on my 2nd mini and as far as I know without moving the fire wall you will require a 90mm extended front.
Posted 14 February 2014 - 11:57 AM
I hope so!
Posted 16 February 2014 - 02:36 PM
theres one on the 16vminiclub that has a k20 in the front, standard round nose to!
