Hi
Are the 3 bolts on an mpi thermostat housing an unusual size. I bought some stainless replacements and they look identical in size but are really tight to bolt in.
Mpi Thermostat Bolts
Bergy
, Dec 28 2013 08:06 AM
4 replies to this topic
Posted 28 December 2013 - 08:06 AM
Posted 28 December 2013 - 02:18 PM
If you get a old bolt and a new bolt point the heads away from each other and then get the threaded ends together then hold them up to the light and see if they match up.
This is just for show
The threads should match up if not there different threads.
should be 5/16 unc
should be 5/16 unc
Edited by ukcooper, 28 December 2013 - 02:19 PM.
Posted 29 December 2013 - 12:06 PM
Maybe corrosion hinders to screw the bolts in. Clean the inside threads from rust. That helped me replacing the bolts.
Watch out for UNC as said before - not UNF ! I would not recommend stainless!
Edited by Alpenflitzer, 29 December 2013 - 12:07 PM.
Posted 01 January 2014 - 03:17 PM
You probably have 8mm
