Where Is The Inlet Filter Situated?
Posted 28 December 2013 - 01:33 PM
AA said there should be a intake filter on my 998cc mini, to prevent the sediment doing this, but he can't find it. Any suggestions?
Posted 28 December 2013 - 01:43 PM
Posted 28 December 2013 - 02:07 PM
There wasn't one fitted until the introduction on the injection Mini's. It is a good idea to fit an inline filter though.
Posted 28 December 2013 - 02:33 PM
as above wasn't fitted on many mini's
the inline filter's are cheap enough on ebay (you will need 2 jubilee clips as well as an empty tank
I'm not keen on clamping rubber pipe (esp the old pipe on mini's) & a good time to check the pipe condition as they do age badly at the fuel tank end
I would fit it the tank side of the fuel pump to protect pump & carb (disconnect battery before starting)
good luck
Posted 28 December 2013 - 03:59 PM
Buy an in-line filter from a motor factors, strip & clean the carburettor and fill with clean petrol. It'll be fine then.
Posted 28 December 2013 - 05:27 PM
