Cutting up a mini
#16
Posted 29 May 2006 - 11:09 AM
BUT...
are the inner wings of any decent order tho cound do with them on a remod for hanors flip front
also the center two feet width of the bulkhead ! as hanor has a tubbie box i want to get rid of
cheers Tarks.
#17
Posted 29 May 2006 - 06:21 PM
Allsort, it's all yours!
#18
Posted 29 May 2006 - 10:24 PM
thanks again
gaz
#19
Posted 31 May 2006 - 11:25 AM
pm'd you gw but dont worry about that now thanks !
BUT...
cheers Tarks.
The inner wings are shot, well the whole front was, but will see what I can do with the tunnel, I need sections of the floor pan and cross member for the cab, but have not had a good look at what I need yet.. I'll cut sypathetically if I can...
#20
Posted 04 June 2006 - 09:47 PM
BUT...
cheers Tarks.
#21
Posted 05 June 2006 - 09:11 PM
Have you this bit of a front panel thats rot free?
As wile diging around at some filler put ther by the PO, have found a lot of rot and a plate has been welded over the top of more rust.
And I don't really want to buy a hole new front panel as the rest of it still seams preaty rot free.
Cheers,
karl
#22
Posted 06 June 2006 - 12:56 PM
Or
I'll be off down the scrappy.
Cheers,
karl
#23
Posted 06 June 2006 - 01:13 PM
did you know that you can buy the fornt corners of the front valance!!
http://www.minispare....aspx?pid=35812
#24
Posted 06 June 2006 - 03:53 PM
I do now
Just thought you could only get the whole panel which
A. Would be a bit pointless for a few inch strip
Or
B. Replace the whole front panel, which I kind of don't want to do as the rest is still rot free.
Only really need a small part of it as the lip that the wing is welded to no longer exists.
#25
Posted 06 June 2006 - 03:57 PM
Consider anything before the A-post scrap...
#26
Posted 06 June 2006 - 05:52 PM
gaz
#27
Posted 11 June 2006 - 07:10 AM
#28
Posted 11 June 2006 - 10:20 AM
Mini-GTI, sent you a pm, but no response... all ready to go...
soz mate been away climbing, will get the payment sorted for 2moz ok mate
gaz
