Some of you may have seen some posts from me before on here, and they all tend to have the same theme: Start enthusiastically and then trail off. I am determined for this to be different, however as I cannot log into mini forum when at work, and my time at home is very limited, it may be some time between posts... so please be patient and continue to contribute whilst I appear to be ignoring this. I am most likely reading it at work but unable to comment myself...
I have bought myself a new engine for my Clubby Estate with the following spec:
- 11 stud engine from an Allegro 1300GT. There is no engine number unfortunately, but I understand these to be very similar to the 11 stud cooper S blocks except the crank will be EN16, not EN40 and some other changes.
- 2 x 12G940 11 stud heads. One of them is marked 12G1805 above the thermostat also. All parts in tact for both heads, although a couple of the valves in one were binding in the valve guides when i took them out, so I guess these were slightly bent (and pobably damaged the guides also).
- I have been told the block has a 649 cam. I have not delved this deep into the engine yet to confirm, and also do not know if it was an original BL Tuning 649, or an aftermarket one.
- also told the timing chain has been replaced for a minispares belt kit. not sure on the benefit this will give other than I assume being quieter.
- Engine also has a later metro distributor without vac advance, and a small pulley on the water pump.
The engine arrived with no head attached, and feeling the bores i think they may need a re-bore. the pistons are already marked +40, so i guess the next step is +60 which would make this a 1340 after the bore? The tops of 2 of the pistons that are currently in there have some pitting on one side so i think these may need replacing anyway, and might as well pay the extra to clean up the bores.
THE PLAN:
- Skim head and get unleaded exhaust seats fitted. I have been quoted £220 for this. is that about right? (I am in SE London/North Kent near Brands Hatch if that helps).
- Re-bore block to +60 and fit new pistons. I have been recommended 21253 pistons for this, but do not really know the difference between different types?
- general health check all around and re build engine to go in the clubby.
I have the occasional assistance of some friends who have done this thing in the past, one of which used to race minis and seems to know the lingo, but generally i am heading into this a little blind (although quick and keen to learn)
I would like to know what people think, any advice or really obvious things to look out for, etc. The intention is to have a car that is happy on a motorway and not a big handful around town. I dont want to set any land speed records in this thing, or have to get the engine to 1 million RPM before it will respond :)
Also, can someone explain to me what compression ratio means in an unleaded engine? I understand roughly what it is, and how to calculate it, but have not read anything definitive on what is a 'good' or 'optimal' compression ratio for an engine running unleaded petrol.
many thanks
Neil.
I will look at getting some pictures up for everyone soon too.
