Norrow Beam
Posted 16 January 2014 - 02:44 PM
Posted 16 January 2014 - 03:06 PM
I have no idea what you are on about !
Posted 16 January 2014 - 03:42 PM
Posted 16 January 2014 - 08:57 PM
Translation:Could I borrow beam my rear subframe and modify the front arms to get the tooked look ?
Could I narrow my rear subframe and modify the front arms to get the tucked look?
It's a popular modification with Beetles, which have torsion bar front suspension and rear suspension, which are totally different to a mini. A mini has proper, working suspension. You could chop it all up to make it look like a beetle, or you could get negative camber front and rear suspension kits and use narrow wheels and brake drums. It's never going to tuck the wheels like a beetle, because there just isn't that much room in the guards.
Posted 16 January 2014 - 09:07 PM
The dampers would all end up at the wrong angle and catch on the wheel potentially on the back
Posted 16 January 2014 - 09:53 PM
Not advised as it would spoil a nice Mini. Use 4.5" wheels and there is no need for wheel arch extensions.
Posted 17 January 2014 - 11:58 AM
Posted 17 January 2014 - 01:06 PM
it's the front your going to struggle with
you can't make the subframe much narrower because the engine sits inside it
Posted 17 January 2014 - 02:20 PM
Posted 17 January 2014 - 05:11 PM
It would look most odd IMHO. One heck of a lot of work for no actual gain.
I can't see how the front hub datum faces can be moved inwards together with the damper mountings and all the other stuff.
On the rear the dampers would need to move inwards and the damper top mountings likewise, at which point they would hit the fuel tank(s).
Once done it would be devalued by a substantial amount as a classic Mini Pick-Up and that would be a pity as later on someone would probably have to put it back to standard.
Posted 17 January 2014 - 06:12 PM
it's the look i have had my wheels stolen look found in the VW scene
Posted 17 January 2014 - 06:16 PM
My gawd, that looks absolutely horrible. Why on Earth would someone ruin a perfectly good VW Beetle by doing that to it?
Posted 17 January 2014 - 06:17 PM
100% agree. Ridiculous idea!
Posted 17 January 2014 - 06:19 PM
to be really cool you next remove the suspension
Edited by Bungle, 17 January 2014 - 06:23 PM.
Posted 17 January 2014 - 06:21 PM
and if you run the car so low that you wear through structural bits of suspension you will be come some sort of god
yes that's about a third of the suspension beam and bottom arm missing
Edited by Bungle, 17 January 2014 - 06:22 PM.
