Headlight Upgrade
39 replies to this topic
#31 1984mini25
1984mini25
  • 8,784 posts
Posted 07 February 2014 - 10:41 PM
Edited by 1984mini25, 08 February 2014 - 11:25 PM.
#32 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 07 February 2014 - 11:15 PM
Thats a great diagram, so is there only 2 relays required ?
#33 1984mini25
1984mini25
  • 8,784 posts
Posted 07 February 2014 - 11:34 PM
#34 splintercat
splintercat
  • 616 posts
Posted 08 February 2014 - 06:03 PM
Phew getting confused here ........1984mini25 .can you please draw me a circuit diagram   using your set up mate  appreciate it bud will pm ya just to make sure   havent got that dip dim relay anyway   come to think of it would appreciate any one sending me a diagram
Hears a quick one I've done in paint.
thanks buddy appreciate this........rock & roll now where are those bad boy high wattage H4s
#35 tiger99
tiger99
  • 8,584 posts
Posted 08 February 2014 - 06:16 PM
That is unsafe, because it has added numerous additional failure modes to the headlight circuit. What happens if a relay fails, not uncommon? Both lights go out at once. And where are the fuses? Upstream of the relays, one blows, both lights go out. It is unsafe to rely on the driver having the presence of mind to switch from main to dip, or vice-versa, if both go out, and it may cause an accident to someone else by shining main beam in their face.
Where are the beefed-up earths to handle the current from uprated lamps, yet another common failure point?
Such modifications add very real risks, of which your insurance company must be fully informed.
There is occasionally some very dangerous advice on this forum, and sadly we have yet more of it. If you don't understand failure modes and effects, please do not give advice on safety critical systems, ever.
#36 tiger99
tiger99
  • 8,584 posts
Posted 08 February 2014 - 06:21 PM
Also, every single time headlights are mentioned, HIDs come up. Please give it a rest, the subject has been flogged to death in the technical section far too many times, and it is known, without any shadow of doubt, that it is just plain illegal to fit them to a Mini, and that goes for LEDs over 2000 lumens too.
#37 Jase
Jase
  • 1,166 posts
Posted 08 February 2014 - 06:46 PM
Can you post an alternative wiring diagram or set of instructions or a link to show how it should be done. That would be a great help, I was going to follow the above but would prefer to do it safely and correctly.
#38 1984mini25
1984mini25
  • 8,784 posts
Posted 08 February 2014 - 11:09 PM
Ok then witch is more unsafe, The standard (in my case 30 year old) wiring melting and the headlamp switch melting/catching fire or a fuse/s blowing? In both cases you'd lose your headlamps....
Edited by 1984mini25, 08 February 2014 - 11:09 PM.
#39 1984mini25
1984mini25
  • 8,784 posts
Posted 08 February 2014 - 11:31 PM
You know what I've pretty much had It with wasting my time with every time I suggest something and being slated for it (I've only been around working, rebuilding and restoring minis for the best part of 15years so clearly know ******* all), So if Tiger99 can't be arsed to come up with a better 'safer' solution there is always this just as 'equally' unsafe advice hear...
http://www.theminifo...e/?hl= headlamp +relays
Edited by 1984mini25, 08 February 2014 - 11:32 PM.
#40 splintercat
splintercat
  • 616 posts
Posted 09 February 2014 - 07:36 PM
lads all I wanted was a bit of advice.........not a  war. This ain't a forum........ its a fight
