Restore it to the correct and safe ride height (there is some leeway for adjustment, but you must never go too low), with the only suitable springing medium for the short travel suspension, which is rubber cones.
Please Help... Suspension Problem ?
#16
Posted 01 February 2014 - 02:01 PM
#17
Posted 01 February 2014 - 02:05 PM
#18
Posted 02 February 2014 - 09:40 AM
#19
Posted 02 February 2014 - 10:30 AM
#20
Posted 02 February 2014 - 04:19 PM
#21
Posted 02 February 2014 - 07:29 PM
Or a local club (other owner) to have a look
#22
Posted 02 February 2014 - 07:30 PM
Have you checked for floor cracking as suggested?
#23
Posted 02 February 2014 - 07:34 PM
I would follow this advice
Check the front subframe mounts especially the rear ones to see if they are not damaged at all. It will also pay you to look at the front toe board to see if there is any cracking / rust around there.
The rear again could be down to wear and tear on the subframe mounts and also the radius arm pins.
#24
Posted 03 February 2014 - 09:08 AM
hopefully is nothing bad....
#25
Posted 05 February 2014 - 12:52 PM
The shock absorber bushes are totally worn all around ! And the mechanic told me that he could take the shock absorber from the body and move it! ...
what do i have to buy ? Is there any kit that includes all bushes for the shocks ?
Can anyone send me a link please!
#26
Posted 05 February 2014 - 12:59 PM
#27
Posted 05 February 2014 - 01:01 PM
Today i had my car checked... finally i found what the problem is.
Are the shock absorbers broken also?
#28
Posted 05 February 2014 - 01:29 PM
#29
Posted 05 February 2014 - 02:21 PM
No the shocks are fine !Are the shock absorbers broken also?Today i had my car checked... finally i found what the problem is.
#30
Posted 06 February 2014 - 05:52 AM
