What Is This Switch For On Mini Dashboard?
20 replies to this topic
#1 Poppet2
Poppet2
  • 135 posts
Posted 20 January 2014 - 12:00 PM
It has a picture of a pedal on it, next to the hazard lights switch.
Is it something to do with the brakes, or clutch or fluid for both?
Edited by Poppet2, 20 January 2014 - 12:01 PM.
#2 FlyingScot
FlyingScot
  • 2,664 posts
Posted 20 January 2014 - 12:12 PM
Here is the explanation from the owners manual
Attached File  image.jpg   65.41K   90 downloads
FS
Edited by FlyingScot, 20 January 2014 - 12:15 PM.
#3 Carlschalch
Carlschalch
  • 24 posts
Posted 20 January 2014 - 12:13 PM
Hi Poppet2
It is your brake warning / tester switch
#4 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 20 January 2014 - 12:17 PM
WOW! It's been ages since this came up.
Don't think of it as a switch, it's your car's low brake fluid warning light. Cars have to be fitted with them, and there has to be a bulb test function because it's a safety item. Current cars use the handbrake warning as the bulb test. In the '70s when these things were new and there was no 'normal' way to design them a few manufacturers decided to do it by having a specific bulb test switch as you do in aircraft systems. That's what this is, pressing the switch tests the bulb in the switch and nothing more. The lamp should also light if you lift the cap off the brake fluid reservoir (unless your car is really old in which case it lights up if one brake circuit loses pressure compared to the other, there is no real easy way to test this type properly). If it does both these things it works, if it then lights up by itself at any time you need to check your brakes urgently.
#5 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 20 January 2014 - 12:21 PM
Congratulations! You are the first 'What switch is this?' thread holder of 2014!
But yes, Dan explains it very well.
The search tool is an amazing thing you know.
#6 Poppet2
Poppet2
  • 135 posts
Posted 20 January 2014 - 12:28 PM
FS
Link working Now.
Thanks.
Edited by Poppet2, 20 January 2014 - 12:34 PM.
#7 Poppet2
Poppet2
  • 135 posts
Posted 20 January 2014 - 12:32 PM
Thanks everyone, and Dan for that explanation.
#8 andy159
andy159
    Speedy fingers.
  • 837 posts
Posted 20 January 2014 - 01:04 PM
classic 20w 50 engine oil is also the best oil to use too
#9 finch661
finch661
  • 2,339 posts
Posted 20 January 2014 - 01:16 PM
where do you get replacement lamps for the switch. mine seems to be missing!
cheers
#10 A-Cell
A-Cell
  • 1,610 posts
Posted 20 January 2014 - 01:45 PM
GLB280
Minispares http://www.minispare...|Back to search
Also Somerford Mini
#11 jaydee
jaydee
  • 8,565 posts
Posted 20 January 2014 - 02:12 PM
Its the kill switch.
Kills your passenger.
Very useful if he/she s making odd noises on tight bends.
#12 minimaxie
minimaxie
  • 1,687 posts
Posted 20 January 2014 - 02:18 PM
Most of the time it's the "she"
#13 Poppet2
Poppet2
  • 135 posts
Posted 20 January 2014 - 10:33 PM
cheers
How can your mini travel through such deep water and still run? Most people would get water in the distributor, even with the shield kit with this amount of water near the grill.
#14 finch661
finch661
  • 2,339 posts
Posted 21 January 2014 - 09:59 AM
cheers
dunno, maybe just lucky! i have a well sealed electronic dizzy. used to have really bad issues when it was wet, but not anymore. also buy some damp start!
#15 miniman24
miniman24
  • 1,696 posts
Posted 21 January 2014 - 10:42 AM
They managed it in the Italian Job, must have wrapped the engines in cling film to do those scenes :D
