What Is This Switch For On Mini Dashboard?
20 replies to this topic
#16 finch661
finch661
  • 2,339 posts
Posted 21 January 2014 - 10:54 AM
you shouldnt have issues with the ignition system if it is well serviced and sealed. trick i learned was smear a bit of grease on the inside of the dizzy cap (where it overlaps the dizzy). this creates a barrier for moisture, and as said above spray the dizzy,coil and ht leats with damp start. this creates a think plastic layer stoppping water from getting in!
#17 Ethel
  • 26,013 posts
Posted 21 January 2014 - 11:46 AM
It also leaves a sticky residue that can hold stuff that the HT electricity can track along. Just keep the cap 'n leads clean & dry. Regarding the brake test, there's a little "dibber" in the centre of the brake filler cap that sinks the float & turns the light on if pressed.
#18 jime17
jime17
  • 948 posts
  • Local Club: None
Posted 21 January 2014 - 12:01 PM
lol @ dibber. I thought the BL parts catalogue listed it as a doo dah.
#19 Poppet2
Poppet2
  • 135 posts
Posted 01 February 2014 - 08:16 PM
where do you get replacement lamps for the switch. mine seems to be missing!
cheers
How can your mini travel through such deep water and still run? Most people would get water in the distributor, even with the shield kit with this amount of water near the grill.
dunno, maybe just lucky! i have a well sealed electronic dizzy. used to have really bad issues when it was wet, but not anymore. also buy some damp start!
Can you post a photo of your well sealed dizzy, also how do you seal yours? Do you also have a weather shield and/or do you put a piece of plastic to in the front of the grill?
I don't know if putting a piece of plastic which is the length & width of the grill, will interfere with the fan or anything else.
Edited by Poppet2, 01 February 2014 - 08:17 PM.
#20 finch661
finch661
  • 2,339 posts
Posted 01 February 2014 - 08:44 PM
cheers
not much to see  for my dizzy, just looks like a dizzy. I havent used a weather shield in years (after mine fell off on the motorway), like i said a tin of damp start works wonders!
#21 DAZNOTTSMINI72
DAZNOTTSMINI72
  • 62 posts
  • Local Club: no one will have me.
Posted 02 February 2014 - 11:29 AM
Doh. Lol. What is the small key for on my keyring?
