Condensation - Any Tips?
Posted 20 January 2014 - 04:17 PM
Can't help the weather, but is there any tips to keep the inside dry as I can start to see little bits of mould on the rear seats.
Gf got me a little electric heater so I can warm it up before I go work so it drys the air out a bit too.
I've got a stormforce cover but it's so annoying taking it on and off all the time.
Any ideas what I could do to stop the moisture? Or can't I really help it?
Posted 20 January 2014 - 04:18 PM
Similar problems here so any advice will be very handy
Posted 20 January 2014 - 04:22 PM
i bought a bag from amazon which is designed for caravans. its a condensor and sucks all the moisture out of the air. the bag i had was a 1kg bag. cost me about a tenner and stopped it slightly. had to put it in the oven once a week to dry it out.
Posted 20 January 2014 - 04:24 PM
Posted 20 January 2014 - 04:33 PM
I'll give the cat litter a go Tam.
See normal condensation like as if been banging in it I don't mind, but silly when the windows are actually proper wet. Might as well sell the mini and buy a moke and use that during winter
Edited by megamini_jb, 20 January 2014 - 04:34 PM.
Posted 20 January 2014 - 04:44 PM
anything with a high silica gel content would do the trick.
Posted 20 January 2014 - 04:52 PM
I used to have one of these in my old car because it was awful in the winter, it worked really well and it cost about £5-10. The mini isn't so bad but is usually a bit misty in the cold nights, I just crack the back window open and it usually clears.
http://www.tesco.com...0g/215-1656.prd
Edited by ShaunaFTW, 20 January 2014 - 04:52 PM.
Posted 20 January 2014 - 05:21 PM
Hopefully it rains tonight, rather it rain than frost as it's only like that when it's frosty out
Edited by megamini_jb, 20 January 2014 - 05:21 PM.
Posted 20 January 2014 - 07:13 PM
I got some silica gel like this, just need to put them in the oven when they turn green.
http://www.ebay.co.u...=item5891d8df49
I've heard if you put some fairy liquid on the windows it stops the windows from misting up.
Posted 20 January 2014 - 07:18 PM
Quite common over here.
I had a bit of moisture in a BMW and just left the cockpit heater on over night with fan, and window slightly open and all moisture was gone!
Posted 20 January 2014 - 07:37 PM
Two of these in your rear bins will change your life.
http://www.ebay.co.u...r-/350856011667
And before you ask, no, i dont work for them.
Edited by jaydee, 20 January 2014 - 07:37 PM.
Posted 20 January 2014 - 09:17 PM
Posted 20 January 2014 - 09:39 PM
It's a bit of an expensive solution admittedly, but when you're not using it in your mini, you can use it to dry your clothes instead of using a tumble drier. Hang your washed clothes in the smallest room of the house and then shut the dehumidifier in there it's them, they cost much less to run than a tumble drier and you should find that your clothes last much longer too!
EDIT: Oh jeez!! I Just read that back and it really does sound like a "top tip" from a middle aged house wife in "Womans Own" magazine!
Posted 21 January 2014 - 01:00 AM
HI
yes couldn't agree with AVVIT more
in my view the only way forward
in fact that's why we do but swap it between the cars
Posted 21 January 2014 - 01:24 AM
Buying some of these now, what do I do with it when they're full of water? Throw away or empty of water? Rather happy buying a 4 pack is cheaper than buying a 1 pack with 2 quantity
