Hi Matt,
Sorry I don't stock anything like that - just make wiring looms to order.
Is there a reason you need the wiring or the stalks??
Posted 22 February 2014 - 07:40 PM
Hi Matt,
Posted 22 February 2014 - 07:43 PM
Posted 15 April 2014 - 07:42 PM
Bump
Posted 16 April 2014 - 03:56 PM
Do you have any details on your relay'ed headlight looms?
Posted 20 April 2014 - 06:42 PM
Posted 26 April 2014 - 11:51 AM
Posted 26 April 2014 - 05:41 PM
How much is spotlight loom
Same question from me. I require a loom for 4 spot lights for my 1996 SPi
Posted 02 May 2014 - 12:21 PM
DannyTip - what details would you like? All are built and tested on my own mini with the correct rated wiring & relays along with a choice of covering?
D291UDV / Richie83 - 2 spot looms are £45, 4 spot looms are £60.
16vclub_rich - what exactly would you be after? engine loom? If so we would need a lot of chat to make sure we make what you need - we don't have the schematics to hand.
Posted 02 May 2014 - 12:27 PM
PM's sent to all :)
Thanks for enquires
Posted 14 May 2014 - 06:35 AM
Good Morning
I am looking to replace the wiring loom in my mini - it's an 1989 Mini 30. I was hoping to add a few bits to it to make the 'driving experience' a bit better - like dab radio, ipod connection mobile phone and sat nav. Not 100% sure how these will be fitted yet but that's what I would want. I dare say most of the loom could be reused but I have my doubts and while I am at the 'everything' out stage I may as well investigate this part. I read from your replies that you can't compete with off the shelf suppliers but for a minor custom one like this how close can we get? As a complete noobie will the individual connectors be easily identifiable when it comes to fitting? When I remove things I take copious notes, label everything and take photos, unfortunately this wasn't done by the previous owner and I am left with yards of wire spaghetti. Is it best to leave the old loom in situ even though I am removing everything for a respray?
I look forward to your reply.
Lee
Posted 14 May 2014 - 07:40 PM
PM sent frogeye.
Posted 14 May 2014 - 09:57 PM
Posted 21 May 2014 - 11:57 AM
How much would it cost for relay operated headlight wiring?
Also are you able to do a small loom for a heated windscreen? Ideally would want a timed relay that takes a momentary switch input and turns on for something like 5 mins?
Adam
PM Sent
Posted 27 May 2014 - 08:07 PM
Did anyone see our car at L2B and take a card?
Posted 04 June 2014 - 12:19 PM
