grease my nipples.
Posted 31 May 2006 - 12:39 PM
ok strange title i know but these are my problems and question.
1, greasing the car. how do grease nipple work. do i have to loosen them at all or do i put the gun on and start pumping..........hmm....that sounds weird.
2, my El Gordo's exsaughts mounts apper to be falling apart and i am in need of new one;s. which ones do i need or are they a universal thing. i got the stock exsaught on by the way on a 1982 998cc Austin Mini HL
cheers.
right must be off. pc is making bad sounds
Posted 31 May 2006 - 01:39 PM
Nope you don't loosen them, just sick the gun on and get pumping till you see fresh grease oozing out.
You should be able get them from places like minispares or even Halfords for some of them on a good day.
Posted 31 May 2006 - 02:08 PM
edit
can someone show me what the very last mount looks like. i can find the block mount for the exsaught but theres a mount right near the end of the exsaught. i need that one as mine is currently a bit of rubber and thats about it.
Posted 31 May 2006 - 02:33 PM
Think cotton bobbin with a bolt sticking out each end.
Here you go......
Exhaust mount
Posted 31 May 2006 - 06:03 PM
Posted 31 May 2006 - 07:15 PM
nah.....well apart from the cotten bobbin one......that looks slightly confusing. also is there any rubber mounts near the engine for the exsaught. might as well get them while i'm at it.
Posted 31 May 2006 - 07:20 PM
One tip while changing them is to use a small bottle jack or similar small jack to support the Weight of the exhaust giving you two hands free to work with.
Posted 31 May 2006 - 07:46 PM
Posted 31 May 2006 - 07:53 PM
evening all.
Posted 31 May 2006 - 09:52 PM
bloody good idea that, cheers Mr1984
Or you could do it the hard way…
While trying to hold the weight of the exhaust, while on you back with you arms stretched above you,
Trying to get the mounts off and then lining the new ones up, without letting the exhaust smack you,
I know what way I would prefer,
Also means you can have a rest half way though without leaving the exhaust to just hang down.
Posted 01 June 2006 - 12:16 PM
greasing the cars nipples
and so you know ere they all are...
