Hi folks,
Anyone got any photos of the two lower mounting points for the rear seatbelts on a later mini (don't need the 'C' pillar one)? Is the outer one through the wheel arch or through the 'bench' part of the seat?
Posted 24 January 2014 - 12:49 AM
Hi folks,
Posted 24 January 2014 - 01:39 AM
You can buy an installation kit that includes the weld on brackets - source of a piccy at least.
http://www.theminifo...-project/page-5
Posted 24 January 2014 - 11:51 AM
Posted 24 January 2014 - 04:58 PM
Isn't that a static belt mount? I was assuming the Op was after the Mpi reel mounting.
Mmm he never made it clear Ethel, oh well im sure he will clarify later.
Posted 24 January 2014 - 07:23 PM
Hi Folks, Already have the C post mounting (removed from a scrap car) so just wanted to see where the two lower mounting points went and what they consisted of............have seen, as posted , the centre mounting points but can't quite make out where the outer ones go..........looks like the outer edges of the seat back.
Will probably get the bracketry from Somerfords.
Posted 24 January 2014 - 07:40 PM
Depends on what belts you're trying to fit. The above relates to static 3 point belts.
http://www.roblightb...iniexamples.htm shows an MPI but not the mounting detail.
Posted 24 January 2014 - 08:35 PM
Posted 24 January 2014 - 09:41 PM
Static is my aim!
