Ok is it me been thick?
Picked up a pair of used subframes and as far as i can see are complete?
Question is where.how do the bolt to the car??
Thanks in advance
Posted 28 January 2014 - 07:19 PM
Thanks in advance
Posted 28 January 2014 - 07:22 PM
Edited by minilee94, 28 January 2014 - 07:23 PM.
Posted 28 January 2014 - 07:55 PM
Posted 28 January 2014 - 08:40 PM
You may need to weld some steel square hollow section across the car where the rear of the seat sub-frames go and fit welded in trapped nuts to hold the rears. Those sub-frames are normally non-hinged, or at least the ones I've seen have been.
Posted 28 January 2014 - 09:07 PM
Ahhh so there is a sub frame mounting bracket in the cross member??
Thinks thats what im missing?
Posted 28 January 2014 - 09:13 PM
The other way is to have two brackets coming down from each side at the back and going right across at floor level with a piece of hardwood about 3" x 12" x 1/2" thick between the support and the floor to spread the load. You then bolt the support bracket & wood to the floor with some spreader plates under the floor. At the front you can normally fit a mounting which picks up on the existing seat brackets.
Posted 28 January 2014 - 09:15 PM
so whats the fixing points on the cross member for? 4 x passive nuts in there?
Posted 28 January 2014 - 11:13 PM
The 4 off trapped nuts each side of the seat are for the standard forward seat brackets.
