Holes/gaps In Lower Flitch = Mot Fail?
16 replies to this topic
#16 tiger99
tiger99
  • 8,584 posts
Posted 31 January 2014 - 01:21 PM
The area where the inner wing, bulkhead/toeboard and sill meet is highly stressed, and on that basis the MOT tester would be entitled to fail it, because it could be unsafe to drive, same as for rust in the middle of a sill, even if it was more than 300mmm from an important mount. In any case it is almost certainly within 300mm of the rear mount of the front subframe, and maybe the damper mount.
Obviously, a good patch weld job will resolve the problem for now, and it will last a lot longer if the rusty area is cut out and new metal butt welded in, followed by proper preparation and paint.
Contrary to what has been said, the front wings are structural, as they brace the inner wing, which carries subframe loads. However, the patch of corrosion does not impair the structural performance seriously, although it will likely be impossible to prevent it spreading without a new wing in the long term.
But, as in all Mini bodywork problems, there is usually more lurking, out of sight. Probably one of the main reasons why I bought a MIG welder many years ago....
#17 CityEPete
CityEPete
  • 3,920 posts
Posted 31 January 2014 - 07:28 PM
I think you could argue that the front subframe actually supports the wings and front panel, the section forwards of the tower mount has no bracing to stop the inner wing flexing which it would easily if there was any load pushed from the front of the subby? It all adds up to be a sturdy little box I guess but how could anyone have a flip front or those snazzy cradle front subframes that attach to the tower and rear only. I know some have a diagonal brace but not all nor do loads of kit cars that are minibased.
