Solar Trickle Charge
19 replies to this topic
#1 robminibcy
robminibcy
  • 1,516 posts
Posted 30 January 2014 - 07:53 PM
hi, can any one reccomend a solar powered trickle charger? Im not using the mini as much at the moment as ive fallen victim to the lure of modern cars luxuries such as demisters and fuel economy! As a result the battery usually needs a jump start. Im using it probably around once a week but often only for a quick thrash so not enough time to fully charge. I dont want to have to take the battery off as it will loose the radio presets and uit also has a tracker alarm system.
Ive found a few on google but many say they are good for batteries up to 50ah, mine is 60? I therefore assume that these shouldnt be used? It would also need to be water proof as the car has an outdoor cover so the charger would have to sit on top completally exposed to the elements.
#2 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 30 January 2014 - 08:00 PM
i bought one from maplin for under £20, supposed to stick it in windscreen.
My car is parked up in a sealed unit with no electric, so ive put it on the wall outside, drilled the wall and extended the cables through. Keeps battery topped up ok when car is stood for weeks.
#3 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 30 January 2014 - 08:02 PM
http://www.maplin.co...e-charger-n59fu
or
http://www.maplin.co...e-charger-l58bf
#4 Cooperman
  • 23,326 posts
Posted 30 January 2014 - 08:13 PM
Solar power, in this wet and cloudy climate :D .
#5 robminibcy
robminibcy
  • 1,516 posts
Posted 30 January 2014 - 08:19 PM
Brilliant. I might pop in at the weekend and see if theyve got any of that first one you linked. Cheers
#6 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 30 January 2014 - 08:27 PM
you can check stock online at your store.
#7 geoff-d
geoff-d
  • 468 posts
Posted 30 January 2014 - 09:08 PM
I have used the Maplins cheap £10 ish to keep race cars charged in all Weather & worked ok
#8 100ev8
100ev8
  • 622 posts
Posted 30 January 2014 - 09:27 PM
http://www.maplin.co...y-charger-n30cx
keeps my dads range rover topped up no prob and it sits for months without use
#9 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 30 January 2014 - 11:03 PM
i too use a cheap Maplin charger
#10 FlyingScot
FlyingScot
  • 2,664 posts
Posted 30 January 2014 - 11:34 PM
Depends on weather, I have two of these units. One from Maplins in a special offer and an older one I bought at a tyre store in Canada many years ago. Worked just about okay when I lived in East Sussex, waste of time now I am in the West Coast of Scotland :D
They are both the second 1.5w model
FS
Edited by FlyingScot, 30 January 2014 - 11:35 PM.
#11 mm man
mm man
  • 405 posts
Posted 30 January 2014 - 11:48 PM
or
Just reserved mine the top one (2.4w) for £12.49 half price at the moment ?
Got to be worth a go at this price
Edited by mm man, 30 January 2014 - 11:49 PM.
#12 Twincam
Twincam
  • 1,742 posts
  • Local Club: SMAG
Posted 31 January 2014 - 01:04 PM
Are you able to get electric to your garage? A smart charger/optimiser such as optimate or similar would be great. Once charged it will monitor the levels and practically turn off until the level drops below a certain level. Oxford make one and Lidl/aldi sometimes have them.
#13 robminibcy
robminibcy
  • 1,516 posts
Posted 31 January 2014 - 03:50 PM
no hence the need for solar power! If I had my way the garage would be empty and the mini,would be snuggled inside! Went in to maplins today and got the 2.4w one. Have to see how it does although in weather like this I don't think it has much,chance
#14 mm man
mm man
  • 405 posts
Posted 31 January 2014 - 08:00 PM
or
It's fitted .......maplin texted me at 8.55am this morning I just happened to be within a minutes walk away so picked it up on works time result ! Got home stuck it in the garage window connected it to the car and away we go ... Could not be any easier took around 3mins
#15 rik_t
rik_t
  • 276 posts
  • Local Club: Robin Hood
Posted 03 February 2014 - 12:50 PM
Please excuse me if this is a stupid question, I have just purchased the £12.49 Maplins offer today. Is there any reason this can't be left on parcel shelve and connected all the time?
