Rev Counter Problems. Please Help!
electrical engine
21 replies to this topic
#1 rust-machine
rust-machine
  • 16 posts
Posted 30 January 2014 - 10:49 PM
I recently purchased my 1983, 1275mini. It has a rev counter but it does not work. I am currently fitting a new dash and am trying to solve the problem whist the wiring behind the dash is all exposed. I have tested the two wires that pug into the back of the rev counter with a voltmeter and they both seem to be giving out currents. But still shows nothing on the rev counter. I even brought a new rev counter and that still did not solve the problem.
Does anyone have any idea what the problem could be here?
Thanks konnan.
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 30 January 2014 - 11:01 PM
Have to give us the make of the rev counter your trying?
#3 rust-machine
rust-machine
  • 16 posts
Posted 30 January 2014 - 11:12 PM
The rev counter is made by smiths
#4 petey81
petey81
  • 1,331 posts
Posted 30 January 2014 - 11:14 PM
Have you checked the connections on the coil?
#5 rust-machine
rust-machine
  • 16 posts
Posted 30 January 2014 - 11:16 PM
Yes, they all appear to all be good working connections :/
#6 petey81
petey81
  • 1,331 posts
Posted 30 January 2014 - 11:30 PM
Is the rev counter earthed? Post some pics if you can.
#7 Craig89
Craig89
  • 600 posts
Posted 31 January 2014 - 06:11 AM
A picture of the face and reverse of the speedo would probably help here. Does the ID of the speedo (wrote on the face) begin RVI or RVC? Do you have electronic ignition fitted or is it standard points?
This info will help to find if you have the correct speedo for your car or if you have a wiring issue
#8 rust-machine
rust-machine
  • 16 posts
Posted 31 January 2014 - 10:00 AM
Thanks for all the help. Here are some pictures
#9 rust-machine
rust-machine
  • 16 posts
Posted 31 January 2014 - 10:04 AM
Attached File  image.jpg   38.33K   10 downloadsAttached File  image.jpg   41.13K   7 downloadsAttached File  image.jpg   36.61K   3 downloadsAttached File  image.jpg   54.65K   9 downloads
#10 rust-machine
rust-machine
  • 16 posts
Posted 31 January 2014 - 10:24 AM
And I believe It's just points.
#11 Craig89
Craig89
  • 600 posts
Posted 31 January 2014 - 10:40 AM
Right ok, standard clocks. You say you tried another rev counter...did you swap the counter in the cluster or try another complete cluster? Just trying to establish weather it could be a break in the tracks on the PCB on the back of the cluster.
If not then it could point to a wiring issue
#12 rust-machine
rust-machine
  • 16 posts
Posted 31 January 2014 - 11:39 AM
Hi
Re rev counter / taco problem
Today linked a live feed from the fuse box
And a feed from the coil
Still no joy
Tried both tacos
Is there any way of testing the rev counter
Or do I need a find taco from a 1993 mini
#13 Craig89
Craig89
  • 600 posts
Posted 31 January 2014 - 12:00 PM
That is how I would test a normal rev counter but I am not familiar with this type. I have done abit of research and it would appear that it is wired like this:
1 - ground/earth
4 - 12v power for the tacho
2 - feed from ingnition switch
3 - feed to positive side of the coil
#14 Craig89
Craig89
  • 600 posts
Posted 31 January 2014 - 12:04 PM
So basically the feed from the ignition switch to the positive side of the coil goes via the rev counter in at 2 out at 3
#15 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 31 January 2014 - 01:15 PM
Craig's information is correct.  You have a Smiths RVI type tachometer, sometimes referred to as an impulse tach.  They do not wire like a modern instrument with a single wire to the coil, they get wired in series with current flowing through the ignition coil.  They are also generally not compatible with electronic ignitions.
If you have problems with the tach after following Craig's wiring scheme, post back with what you did and what is happening and we'll elaborate on things to check and do.
Also tagged with one or more of these keywords: electrical, engine
