No BRAKES!!!
Posted 01 June 2006 - 01:00 PM
Any suggestions welcome, im also using metro turbo calipers if that helps.
Posted 01 June 2006 - 01:14 PM
Have you bled the rear brakes in the correct order according to Haynes?
Posted 01 June 2006 - 01:17 PM
Posted 01 June 2006 - 01:19 PM
Posted 01 June 2006 - 01:22 PM
Posted 01 June 2006 - 01:25 PM
One sec and I'll do a touch of reading...
EDIT: Also, just thought, check for any splits or leakages in the lines and fixings from the servo to the engine.
Posted 01 June 2006 - 01:30 PM
Posted 01 June 2006 - 01:43 PM
Posted 01 June 2006 - 01:55 PM
Posted 01 June 2006 - 03:45 PM
I think you need to have the servo hose connected to the manifold though.
Posted 01 June 2006 - 04:27 PM
Posted 01 June 2006 - 05:15 PM
Won't that just introduce a load of moisture to your brake fluid??Take the cap off the master cylinder and jam a piece of wood between the pedal and steering wheel (so the pedal is pushed to the floor). Leave it overnight and see if it makes a difference. Don't forget to put the cap back on when you've done!
Posted 01 June 2006 - 05:18 PM
I am not familiar with the 4 pots, but isn't there two bleed nipples on them and aren't they always a pig to bleed? I know there are two pipes that go into em on the metro aint there? Do you use a link pipe when fitting them to a mini? I am guessing that could be the issue?
Anyone got a piccy of some 4 pots?
I am assuming you are not loosing any brake fluid anywhere either? Rear cylinders OK and everything? Are the brakes in a generally good condition?
Posted 01 June 2006 - 05:22 PM
Its a good diagram on how a brake servo works. Basically, if your servo splits then you will just get no servo assistance on the brakes, but it will not cause you to not be able to stop.
Second, no, there's no hydraulic system in the servo.
You just have a brake bleeding issue. Make sure you bleed them properly in the correct order. use new fluid and only complete the bleeding when you see new fluid coming out of the cylinders. (to make sure you don't have contaminated fluid). If you think you won't be able to tell new from old, get some coloured fluid (ATE do a good grade Blue fluid).
DON'T leave the cap off overnight. You'll only encourage more moisture into the system (Brake fluid is hydroscopic). by all means use the plank of wood trick though, but I don't see it helping.
Also, have a good look round the components of your system. Do you have any leaks, any bulging flexible lines, any bad corrosion, are the components bolted to the car properly etc etc.
Posted 01 June 2006 - 05:39 PM
dave
