Bob Runs Better With The Choke 2 Peg Width Out
23 replies to this topic
#16 Minigirl
Minigirl
    With Steve
  • 1,109 posts
Posted 03 February 2014 - 10:05 AM
Is static advance when the engine is at idle?
Do I need one of them adjustable timing lights?
(message sent from my Partners account)
Edited by Minigirl, 03 February 2014 - 10:05 AM.
#17 welshdan
welshdan
  • 643 posts
  • Local Club: ?
Posted 03 February 2014 - 11:23 AM
Get this to a rolling road who know what they are doing. Otherwise it will end up in tears. And you probably won't ever realise the true potential of the engine s performance
#18 Steve-O 2014
Steve-O 2014
  • 312 posts
Posted 03 February 2014 - 11:43 AM
luckilly we have not done many miles with it like this. If we collected the car instead of having it delivered it could have been 140 miles sat on the motorway running lean!!!!
#19 emmybean
emmybean
  • 13 posts
  • Local Club: Robin Hood Minis
Posted 03 February 2014 - 12:12 PM
you dont NEED to pay for an engine tune, although highly recommended and i cant wait to get around to it. Simply adjust your timing, have you a haynes manual? check your vaccum advance timing is right, 8 degrees from tdc... ( tdc also explained in the later haynes manuals or on this forum) and then ignition timing, by turning the dizzy. all explained in the manuals or here somewhere. Just set the 8 degrees and then set the ignition timing so it sounds right when warm/ idles at the right speed :) Let us know if you sort it.
#20 minimender
minimender
  • 1,589 posts
  • Local Club: M.M.M.
Posted 03 February 2014 - 06:47 PM
Static advance is when the engine is stopped (not running)
Timing light is good,  any will do, highlight timing marks on engine and pulley with tipex so you can see them better.
Do it with Vacuum pipe off the distributer
Can just set static if you want and see how it goes, advance a little and see if its better, you can advance until it pinks under load but then must turn it back a little cause pinking is bad
#21 Rog46
Rog46
  • 465 posts
  • Local Club: NSMOC
Posted 03 February 2014 - 09:24 PM
I've always had good results setting the mixture with a colourtune maybe not as good as a rolling road but very good!
#22 minimender
minimender
  • 1,589 posts
Posted 03 February 2014 - 09:44 PM
+1
#23 Steve-O 2014
Steve-O 2014
  • 312 posts
Posted 04 February 2014 - 10:37 AM
Thanks, someone that knows all about classic minis is going to look at it on the weekend so hopefully we will get him sorted
Then it will be time to sort the oil leak, From Max to Min in a week.............
#24 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 04 February 2014 - 02:56 PM
thats a severe oil leak... where is it coming from? my guesses are
gear selector shaft (rod change)
diff output seals
distributor
