im in utter confusion ive rebuit my engine (1275) and fitted a 266 cam i have a vernier timing gear so i dialled the cam in found tdc on number one and then set the timing disc on and turned it to cam full lift then using the protracter set it to 106 degrees, ive put it all back together and set the distributor drive correctly but it missfires untill i change number 1 and 4 plug leads
1 reply to this topic
Posted 08 February 2014 - 07:07 PM
Posted 08 February 2014 - 10:49 PM
I assume that you timed the cam at 106degs max lift ATDC on the inlet, then you need to check that the distributor drive shaft is inserted in the correct position so when no1 cylinder is at TDC firing the rotor arm is pointing at the 1-2 oclock position, if yours is at the 7-8 oclock position then the shaft is 180degs out
Mini Technical Sections →
Problems, Questions and Technical →
Excessive Fuel Pressure - Regulator Or New Pump?Started by daddums , 20 Aug 2025 ![]() |
Econoseal Or Something Else?Started by o0OWILKSO0o , 13 Aug 2025 ![]() |
What Size Are These Main And Big End Bearings?Started by scottyboy805 , 19 Jul 2025 ![]() |
engine
Spi Bad Idle And 'tapping' Engine SoundStarted by Simmi Westo , 15 Jul 2025 ![]() |
![]() Help! Water In Oil Question....Started by TerryLee , 06 Jul 2025 ![]() |
