Reverse Lights Not Working - Newbie Needing Help!
3 replies to this topic
#1 MiniMod
MiniMod
    Starting My Mini Up
  • 2 posts
Posted 09 February 2014 - 11:42 AM
Hi everyone, new to this website so please excuse me if this is a regular issue.
My reverse lights are not working, I've changed the bulbs which hasn't worked and I don't think it's the fuses as the break lights and indicators are working.
It's a 92 Mini Sprite. Does anyone have any idea what it could be and how an amateur like myself could fix it?
Many thanks!
John
#2 richw911
richw911
  • 2,084 posts
Posted 09 February 2014 - 11:45 AM
The reverse switch located below the gear lever. It could just be a broken wire at the switch or the switch itself. Check the wiring in the boot too
#3 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,017 posts
Are the plugs that run from the gear selecter up clean/ conected? They should be under the carpet from the gear selecter
#4 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 09 February 2014 - 12:31 PM
  Lift the carpet under the heater.  The reverse lamp switch is plugged into the loom at a point on the bulkhead, stamping on the carpet can sometimes unplug it. Chase the cables right up to the dash and check its all plugged up.
