ive had a run though the forum but im not sure if this is just a problem for me not a common one?!?!
The low down...
Indicator stick will beep the horn when pressed
when i move it to indicate nothing happens up front,rear, dash lights or any clicky sounds happen
when i put the hazards on they only work on the rear lights & dash lights and i get a clicky sound but nothing on front lights
i have checked the fuses and the green wire to the fairly new fuse box they look fine, i have also taken out and pushed back in the relays in case a loose connection
This morning tho when it was working i did indicate and the dash light and the clicky sound was going overtime like double speed but no idea if front one was working i thought nothing of it until on my way home tonight and it didn't work at all
Any help in the right direction is appreciated
