I've today picked up my 1979 Mini 850. After adjusting to the completely different driving style, I really enjoyed driving him. However a few issues become apparent after I picked it up which I wonder if anyone can offer advice with?
First of all, the heated rear screen doesn't work. I haven't had chance to check if there is any current at the screen, but I did notice the switch was warm (not ridiculously hot, just warm to touch). Where on the circuit does the heated screen normally fail?
Secondly, the temperature knob for the heater doesn't seem to do anything. It seemed like it was stuck, until I gave it a good pull and then it come right out, but still didn't do anything. What's likely to have gone wrong here?
Thirdly the brake test switch doesn't seem to light up when I push it (my least concern to be honest), but if anyone has suggestions then I'd like to hear them.
Next, I think there might be a slight water leak in each corner of the windscreen, doesn't seem to be major though as there is no rust immediately under it. obviously though I want it fixed before it causes rust, but will that mean taking out the whole window seal?
Next issue was water on the rear wheel arch padding ( the bit just above the bins). It looked like condensation as it was evenly spread all over the upholstery rather than if it had dripped onto it. Should this be a concern for me?
Light behind speedo seemed to momentarily flicker (just for a short period), along with the HB blue light. Likely to have been a loose connection somewhere?
Also the Oil Pressure read around 70-75 under acceleration, and between 45-55 on idle (on a 71k mileage), does this sound ok?
Not being a Mini owner before, it also sounded a little fast/loud on idle with the choke fully in. It seems like the last bit of the choke makes no difference. Is this just how Mini's are?
Only other issue was the wiper park switch doesn't work, but after reading these forums I was expecting that!
Don't want this to make it sound a basket case though, the body seems very solid, and the engine feels smooth and responsive (about as responsive as a 35 year old 850 engine can be!). Drove back about 40 miles today on the motorway in a biblical rainstorm, the engine didn't miss a beat. Just touched 70 mph in it, sounded like it was going to explode at that point but I guess that is just the 850?!
