Self Tapping Screws
18 replies to this topic
#16 mab01uk
mab01uk
  • 12,479 posts
Posted 20 February 2014 - 11:56 PM
Also beware of using too long self-tappers around the grille area and piercing the wiring harness behind.......quick release grille buttons solve the problem:
http://minispares.co...MS.aspx|Back to
#17 bikewiz
bikewiz
  • 321 posts
  • Local Club: NEMO
Posted 21 February 2014 - 02:43 AM
I used stainless 5mm rivnuts after drilling I painted the hole and inserted the rivnut. This link gives pretty good info on dissimilar material corrosion.
http://www.estainles...corrosion.shtml
In order for you to have galvanic corrosion you need an electrolyte such as salt water so if you wash it regularly it won't be much of a problem. Probably less so than the original steel on steel sheetmetal screws.
#18 69k1100
69k1100
  • 376 posts
Posted 21 February 2014 - 10:17 AM
You could also install a sacrificial anode if you're really worried :)
#19 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 21 February 2014 - 10:34 AM
Blimey,who knew that choosing grille screws could be so complicated!! Personally I use grille buttons and therefore don't have the worry of corrosion issues, they also make routine removal and refitting of the grille a darn sight easier too!!
