I am getting wet floor pans as well as all the carpets and soundproofing up to the bulkhead. Is the most likely cause the windscreen gasket (it's the original from '78) or from somewhere else? If the former, what success have people had with products like seek 'n' seal?
Porous Windscreen Gasket/leaking Elsewhere?
Posted 22 February 2014 - 09:26 AM
Posted 22 February 2014 - 09:45 AM
Check the door rubber seals, the door strap rubber boot for splits and if not I would put a new windscreen rubber in. (a good quality one mind)
Or have you got holes in your floor!
Posted 22 February 2014 - 10:26 AM
Posted 22 February 2014 - 04:09 PM
Posted 22 February 2014 - 04:15 PM
Check around air vent area too.
Posted 22 February 2014 - 04:17 PM
Posted 22 February 2014 - 04:18 PM
The windscreen seal perishes as it gets older so as thy are not expensive I would replace it and the fillet strip as well.
and use a good quality sealant like this http://www.frost.co....een-sealer.html
Posted 22 February 2014 - 04:19 PM
and use a good quality sealant like this http://www.frost.co....een-sealer.htmlThe windscreen seal perishes as it gets older so as thy are not expensive I would replace it and the fillet strip as well.
In theory you should not need a sealant but the above would be good and use a standard width seal and the not wide type.
