Trouble Starting
#31
Posted 25 February 2014 - 10:44 PM
Or the jet is clogged(unlikely though)
#32
Posted 25 February 2014 - 10:50 PM
Have tried with choke fully on and off and every stage in between but, again, not even a cough.
The plugs are wet so something's coming through but I don't think it's enough
I eliminated flooding as it starts if I put fuel directly into the bores but happy to be corrected in that if I'm presuming wrongly
#33
Posted 25 February 2014 - 11:08 PM
Keep trying pal. Don't give up you'll get there soon. I don't know if the vac leak is a red herring, but if the leak is big it definitely won't start. Even a very small leak can prevent it starting. You could always try rubbing some grease around the gaskets to temp seal if you're having trouble with wd 40.
Just a thought but can you hook up with a local club to see if one of the guys can help you out. I'm sure they would. We don't need much of an excuse to get under a mini. I don't know what area you are in ?
#34
Posted 25 February 2014 - 11:13 PM
I'm in Essex and keep meaning to join Essex mini club but have just never got round to it, maybe this is my excuse to do it
#35
Posted 25 February 2014 - 11:17 PM
If I was near I'd pop round but from me to you is too far unfortunately.
Don't give up
#36
Posted 25 February 2014 - 11:18 PM
#37
Posted 25 February 2014 - 11:23 PM
If nothing else works I'm tempted to get a rebuild kit for the carb, even if it just eliminates another possibility
#38
Posted 26 February 2014 - 07:57 AM
do you have a good spark? clean inside the centre ht lead connection in the ignition coil, it could be that you have a poor spark. it has to be something simple if the petrol is good (new petrol not old stale crappy stuff) and plugs are wet on turning over.
#39
Posted 26 February 2014 - 03:46 PM
#40
Posted 26 February 2014 - 04:48 PM
#41
Posted 26 February 2014 - 07:45 PM
Tried using grease for the vac test but no difference, narrowing down to the carb being a problem somewhere
Edited by stevelane, 26 February 2014 - 08:03 PM.
#42
Posted 26 February 2014 - 08:16 PM
You can try to sea if there is a leak at the brake servo thingy é manifold.. AND you can try to use quickstart spray orso directly there...
Or try something like that instead of the wd40, if it fires you also know its a vacuum leak..
#43
Posted 26 February 2014 - 08:43 PM
Brother in law had said that he had backed the mixture right off to lean but when I turned it back it went a long way so he couldn't of
Thanks for everyone's help, grinning like a Cheshire cat now!!
Edited by stevelane, 26 February 2014 - 08:43 PM.
#44
Posted 26 February 2014 - 09:11 PM
Congrats :)
#45
