As nick says re-removal, although I use a piece of angle iron drilled so that it fits over two hub studs and then it wedges the hub against the floor on stops it moving.
The torque settings, presuming you have disc brakes are as follows,
Where there are two split pin bores in the CV joint the hub nut must be torqued to 150 lbtft / 207 Nm, then tightened further to align the hole.
Where there is only one split pin bore the hub nut must be torqued to 193 lbft / 262 Nm, then tightened further to align the hole.
Edited by RedRuby, 24 February 2014 - 01:13 PM.
