Minispares Rear Valance Closing Panels - Are They Same?
13 replies to this topic
#1 Wise Old Elf
Wise Old Elf
  • 1,655 posts
  • Local Club: Club Lotus
Posted 28 February 2014 - 06:38 PM
http://www.minispare.../ALA5528MS.aspx
http://www.minispare...24.aspx|Back to
Apart from one being a Heritage are these both the same?
There is a big difference in price at £34.18 and £16.66. Has anyone used the cheaper ones are they a good fit?
Jason
#2 se_juggles
se_juggles
  • 1,043 posts
Posted 28 February 2014 - 06:40 PM
I only use heritage personally so couldnt comment on the cheap ones but the heritage ones are amazing
#3 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,017 posts
Posted 28 February 2014 - 06:41 PM
I made my own from 1.2mm sheet steel, alot better than the ones you can buy IMO as it's mainly one peice.
Edited by alex-95, 28 February 2014 - 06:43 PM.
#4 Tommyboy12
Tommyboy12
  • 2,252 posts
Posted 28 February 2014 - 06:43 PM
Pattern panels are a bit hit and miss. Some are good. Some are bad. Small panels like a-panels and closing panels are usually ok when using pattern.
Even heritage panels arent great now. The tooling is very worn after producing over 5 million cars!
#5 72clubman
72clubman
  • 443 posts
  • Local Club: Charnwood Minis
Posted 28 February 2014 - 06:48 PM
I can also vouch for the heritage ones it's a really nice panel. It's also double skinned where the bolts are so nice and strong.
#6 Wise Old Elf
Wise Old Elf
  • 1,655 posts
Posted 28 February 2014 - 07:11 PM
Thanks for the responses. I was going to make them but found these cheaper ones that look the same as the Heritage ones for half the price.
Is Simon about? Are these any good?
#7 [email protected]
[email protected]
    Minispares
  • Minispares
  • 3,202 posts
  • Name: Simon Jackson
Posted 28 February 2014 - 07:53 PM
Original panels are always (nearly) better than the aftermarket. But these new rear closers are on fresh tolling and are pretty close to them
#8 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 28 February 2014 - 08:12 PM
Jason
Is the rear valance genuine or not? The heritage ones are a good fit if the rear valance is original or heritage replacement but not that great if it has something like a magnum one. If its a pattern rear valance then I would save your money.
#9 Wise Old Elf
Wise Old Elf
  • 1,655 posts
Posted 28 February 2014 - 08:41 PM
Thanks Simon I will give them a whirl.
The rear valance is a Magnum one. I am not happy with it but will have a play with it before condemning it.
Thanks for the help.
Jason
#10 Wise Old Elf
Wise Old Elf
  • 1,655 posts
Posted 01 March 2014 - 10:29 AM
Ordered a pair this morning. Its a bit strange that one is dearer than the other?
I will let you all know how they fit with the Magnum rear valance.
#11 Marco1972
Marco1972
  • 822 posts
Posted 25 March 2014 - 04:19 PM
I was looking at these also
It is funny one being more expensive that the other why is that ???
Look out for your update pics too please
#12 RossKnight
RossKnight
    One heck of a member
  • 2,539 posts
  • Local Club: JKSA MOC
Posted 25 March 2014 - 04:21 PM
I have a magnum valance, and both magnum closing panels in my room now, if you want any photos close up to see quality, fit etc. I'm happy enough with them.
#13 Marco1972
Marco1972
  • 822 posts
Posted 25 March 2014 - 04:35 PM
Yes mate
That would be useful I have the magnum rear valance just undecided on which closing panels to get
Cheers Mark
#14 Wise Old Elf
Wise Old Elf
  • 1,655 posts
Posted 26 March 2014 - 05:34 PM
Here you go.
The closing panel and the valance are all Magnum items. The subframe mounting holes do not line up with the holes I drilled in the floor but this may be more to do with the fact I have rebuilt both corners. In the pic the closing panel is welded to the floor but the valance is not welded on. As you can see the curve of the valance is not great and will need to be pushed and pull about a bit to fit. I have had a bit of a play with it and its getting better.
Overall I would recommend the closing panels but I would not expect the holes to line up. This is an easy fix by bolting the subframe on by the front mounts and redrilling the rear mount holes. I could have moved the closing panel further to the rear but then the flange would not meet the wheel arch flange.
Jason
Edited by Wise Old Elf, 26 March 2014 - 05:36 PM.
