Woooooooooooo there nelly!
AirHorns are not illegal at all!
They are only illegal if mounted up front, on a car 1973 or later.
You can fit airhorns where ever else you like, hence we spoke about fitting them on the rear subframe.
The only other part is, your not really surposed to play them after 11pm at night. But you should all know that if you have a drivers liesence
Best place to put musical airhorns...?
Dog
, Jun 05 2006 07:56 PM
20 replies to this topic
#16
Posted 11 June 2006 - 09:31 AM
#17
Posted 11 June 2006 - 10:39 AM
ah bugger. so mine mounted on the front on the fresh air vent tube thing is illegal. oh dear,
and i know about the noise laws. well.......i do now,
#18
Posted 11 June 2006 - 10:57 AM
Why is it illegal to have them up front, but not anywhere else? If I removed the horn,. fitted airhorns somewhere else and wired the airhorn into the existing horn switch would the car still pass an MOT?
#19
Posted 11 June 2006 - 11:12 AM
This is absolute rubbish and you should subject to ridicule whoever told you this little gem.
Air horns are legal for use on post '73 cars, as all other horns are provided that they produce a constant tone. Doesn't matter if there are two or more horns of different notes as long as they all sound at the same time and the tone you hear doesn't change while they are sounding. This is why musical air horns are illegal while normal air horns are not and it doesn't matter where they are mounted on the car. Incidentally, the construction and use regulations don't only apply to vehicles used on the road. They apply to all licensable motor vehicles wherever they are so technically these horns are just as illegal off road as on in the same way that 'show plates' are illegal to use at shows.
Adam, I seem to remember reading that you didn't bother using a relay in your air horn installation. If you have fitted an air horn compressor into your normal horn wiring there is a good chance of a fire starting in your car. The compressor draws more current than the standard peizo horn and probably more than the wiring is designed for. That's why relays are a good idea, or as Jake said a complete new circuit and switching in the right gauge of cable if you don't mind high current cables and switches inside the car which I personally try to avoid.
#20
Posted 11 June 2006 - 11:16 AM
well were dose the little relay go then. my horn is just a constant tone. but from the diagram (what i rember) it wired into the orignal horn somehow too.
edit
actualy i'll go into the probems board with this.
edit
#21
Posted 11 June 2006 - 12:43 PM
only musical ones, another stuipid law
