Hi Guys , Name is Stephen and this is my first topic,any info would be great.Im building a zcars vtec mini and everything so far is coming along nicely. The issue or concern i have is with the wheels im using, the are 13x7 ET-7, 4x101.6 with a centre bore of 65.1 mm JBW minilights.
when fitting them to the front drive flange which is a standard mini flange with big brake kit the wheel has no support surface to sit on, and because of this the wheel studs are therefore taking all the weight of car which cannot be good! and because of the flange design a collar cant be used to make up the difference between the tiny lip on flange and the inner centre bore of wheel which is 65.1mm bit long winded but i hope it makes sense if anyone has come across this before Any help would be greatly appreciated. zcars brake 2.png 429.84K 8 downloads zcars brakes 1.png 446.34K 15 downloads zcars brake 4.jpg 35.44K 5 downloads
Edited by Stephenk20mini, 04 March 2014 - 07:00 PM.
