Vtec Brake Master Cylinder And Pwda Question
2 replies to this topic
#1 mstanford
mstanford
    Starting My Mini Up
  • Just Joined
  • 3 posts
Posted 05 March 2014 - 03:03 AM
Hi guys, Im building up a Vtec Z cars kit here in New Zealand. I have the front subframe installed and am thinking of finishing the front end before saving hard for the engine and rear subframe.
I have a pair of metro turbo calipers and vented discs- I have done some research and believe I need to order the Yellow tag Master cylinder- is this correct?
Also do I need to buy the PWDA valve or can I just run an Adjustable brake bias valve on the rear line?
What length are the Z cars front flexible hoses- same as standard mini?
I will be ordering in some parts from Mini spares all the way to NZ so cant really afford to get it wrong!
Thanks for any help/advice
Matt
#2 filski
filski
  • 162 posts
  • Local Club: Essex Mini Club
Posted 05 March 2014 - 08:26 AM
Why not run a servo especially if you have space in the engine bay???
#3 mstanford
mstanford
    Starting My Mini Up
  • Just Joined
  • 3 posts
Posted 10 March 2014 - 08:48 PM
Hey Filski
I really wanted a super firm pedal for heel/toeing- you think a servo a better idea?
Would I still need PWDA or just use the wilwood adjuster?
Matt
