Hi....just a thought, has anyone successfully fitted a warning light of sorts to the choke cable/mechanism.
I am the only one that will drive the car that can remember manual chokes and can envisage a lot 'choke' out journey's!!
Posted 05 March 2014 - 05:38 PM
Posted 05 March 2014 - 05:55 PM
You could use a cable and switch off a Triumph, they had a choke warning light and the switch just earthed out the negative cable to the bulb
Posted 05 March 2014 - 05:57 PM
Posted 05 March 2014 - 06:03 PM
It shouldnt be something you forget to be honest, on my car I usually find by the bottom of the road the engine running about 1500 rpm, and everytime I notice the rpm go up the choke goes in a bit and so I cant see you forgetting its out as any time you stop and the engine idles you will notice it running a lot faster than the 8/900 rpm it should be at
Posted 05 March 2014 - 06:22 PM
Posted 05 March 2014 - 06:24 PM
Quite agree!!! It's in no way necessary - but if the OP wants one why not....... came across a mini a while back with an ex triumph "fasten seatbelts" light - was intruiged for a mo.... then realised it was a take off from the alternator warning.....bit shoddy but it worked![]()
I am all for vintage OEM+ type of features like the fasten seatbelts lights, smiths did a round gauge type one
But they tend to all be a bit gimmicky and pointless other than for aesthetics
Posted 05 March 2014 - 06:44 PM
Thanks for your replies, as I said (checks over shoulder!) its not for me
Posted 05 March 2014 - 06:55 PM
Ahh the old "The choke is there to hang the handbag on" ?
Posted 06 March 2014 - 10:49 AM
I've still got a choke cable from a MkI Astra in the random spares pile that has the switch on for a warning light - it was something I was going to fit but never got around to it in my Minis and the GTM doesn't have one.
Iain
Posted 06 March 2014 - 01:25 PM
My choke cable never bloomin stayed open on its own..had to hold it or jam with a clothes peg. I have s/c injection now but use the choke level to hang my CB radio handset on...!
Posted 06 March 2014 - 01:37 PM
I use a locking type choke, never had to use a peg or had any issues.
Posted 06 March 2014 - 11:51 PM
I recently helped a friend with the choke cable on his '78. His choke cable would not twist-lock so he ordered a new one. It wouldn't lock either and BOTH cables also failed when the knob spun on the cable from trying so hard to twist the choke to lock. I repaired the knobs on both and modified the metal rods behind the knob so it really would twist-lock. The early choke cables lock much better without modification.
Kernow, what Triumph had the choke light? I'm just curious as I haven't seen one (yet).
Posted 07 March 2014 - 01:14 AM
Pretty much all of the cars from 70 on Doug 1300/1500/Dolomite/2000/2500Pi/Stag
here is the cluster from the centre of the dash
My dad was a Triumph man bless him
Edited by KernowCooper, 07 March 2014 - 01:15 AM.
Posted 07 March 2014 - 01:44 AM
Ah... that explains it. The only one of those that made it to the U.S. in the 70s was the Stag. The 2000 made it here only for a very, very short period (in the 1960s). The block in my GT6 is actually from a 2000 with a few mods to fit. I have a friend with a project 2000 Estate that's been in pieces for years... I never saw it on the road. I have never seen choke lights on Spitfires, TR-6s, or TR-7s but that's not to say they weren't there on the later cars.
Edited by dklawson, 07 March 2014 - 01:44 AM.
Posted 07 March 2014 - 09:33 AM
I've got one of those clusters in my GTM. They were also fitted to Scimitars (SE6's anyway).
Predecessor of the Bright 6 module.
Iain
