Exhaust Help
23 replies to this topic
#16 greggy50
greggy50
  • 435 posts
Posted 06 March 2014 - 12:12 AM
It's the twin exit which causes the problem. If you want a twin exit on a 998 the diameter of each final exit pipe should be about 1.2".
For optimum efficiency it is vital that the final exit is the same cross-sectional area as the rest of the pipe from the end of the ex. manifold in order to keep the molecular velocity of the exhaust gas the same at the exit as at the end of the ex. manifold. If the final exit is larger, the velocity is reduced and the pressure increased. Think of a hose pipe and think what would happen if the very end was made a larger diameter. The water would not exit efficiently or cleanly. It is basic physics.
I am surprised at Maniflow selling that final exit box. It is vital that the final exit cross sectional area is the same as the main pipe. The science is called 'Bernoulli's Theorem' - check it out if you wish.
Okay cooperman will take your word for it as respect the fact you have a lot more expertise on the subject that myself :)
So I presume I need
1 x Maniflow Centre Exit Exhaust (proper silencer)
http://www.minisport...single-box.html
1 x Maniflow Manifold
http://www.minisport...b-manifold.html
Edited by greggy50, 06 March 2014 - 12:14 AM.
#17 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 06 March 2014 - 12:22 AM
No you want a freeflow manifold on the 998 engine its better than the lcb on the small bore engine here http://www.maniflow....56&product=1507
#18 greggy50
greggy50
  • 435 posts
Posted 06 March 2014 - 12:25 AM
Okay thanks
Would I be right in assuming that the centre exit exhaust would fit directly into the manifold itself?
And then I just need to locate the correct fitting kit with brackets/gaskets etc...
Thanks (sorry I seem such a idiot!)
#19 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 06 March 2014 - 12:34 AM
Manifold/Centre Pipe/Silencer 3 parts mate
#20 greggy50
greggy50
  • 435 posts
Posted 06 March 2014 - 12:41 AM
Yes it comes with the centre pipe already :)
So think will go for this
Free Flow Manifold £72 inc VAT
Maniflow Centre Exit £80 inc VAT
So just over £150 which doesn't seem too painful...
Thanks everyone!
#21 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 06 March 2014 - 12:52 AM
http://www.maniflow....56&product=1085
. :tumble:
#22 greggy50
greggy50
  • 435 posts
Posted 06 March 2014 - 01:07 AM
Just seen the adaptor part... However literally just become a TMF+ member and with my 7.5% discount it appears minispares are by far the cheapest option now
Think this is what I need to order :)
Exhaust Manifold
http://www.minispare...c/C-STR816.aspx
L71 Adaptor
Exhaust
http://www.minispare...C-ARA332SB.aspx
Total = £160 inc delivery
-       7.5% Discount = £148 = Bargain :)
Edited by greggy50, 06 March 2014 - 01:08 AM.
#23 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 06 March 2014 - 01:16 AM
looks good
#24 Cooperman
  • 23,327 posts
Posted 06 March 2014 - 11:01 PM
That is an absolutely ideal system for a 998 and will be good for a modified engine as well. On a 998 it won't be too noisy and will work efficiently, maximising the power output. It's a top quality product as well and I think you'll notice the power increase too.
