Rough Running
7 replies to this topic
#1 Hmsrinkers
Hmsrinkers
  • 12 posts
  • Local Club: 998
Posted 07 March 2014 - 06:11 PM
So I got the old boy out the garage for the first time this year, anyway last year I fitted a new down pipe .. (Old one had a hole in it) and was never running right since as obviously I had to remove the carb and disconnect the throttle and choke cables ...
My question is does the choke cable need to be fitted completely slack ? But If I do this I can't adjust the idle as the idle screw uses the face of the choke housing to wind in to adjust the idle (if that makes sense) I've tried faffing about 10 times with the choke and thottle cables but can't get the car to run right. Won't idle nice and splutters/pops
Any advice would be appreciated .. :)
#2 RedRuby
RedRuby
  • 1,201 posts
  • Local Club: No
Posted 07 March 2014 - 06:33 PM
Just a though have you got fresh fuel in, as it goes stale more quickly nowadays
#3 Hmsrinkers
Hmsrinkers
  • 12 posts
  • Local Club: 998
Posted 07 March 2014 - 07:05 PM
It's a good few months old .. Was running ok before the exhaust change.. Possibly the mixture screw needs adjusting too
#4 jime17
jime17
  • 948 posts
  • Local Club: None
Posted 07 March 2014 - 07:21 PM
What carb is it?
#5 Hmsrinkers
Hmsrinkers
  • 12 posts
  • Local Club: 998
Posted 08 March 2014 - 11:15 AM
It's a 1990 so looking at it and the Haynes it's a su hs4 any help would be appreciated .. Gona try and get it to work properly tosah
#6 Hmsrinkers
Hmsrinkers
  • 12 posts
  • Local Club: 998
Today* rather
#7 jime17
jime17
  • 948 posts
  • Local Club: None
Posted 08 March 2014 - 06:37 PM
Idle adjust screw on hs4 is recessed on the top pointing downward. You need the air filter housing off (assuming a standard one) to get to it.
the jet should be in its uppermost position with the choke knob in.
You adjust the height if the jet and therefore the fuel air mixture with the brass nut around the jet near where it enters the carb from underneath.
#8 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 08 March 2014 - 11:43 PM
By the description your trying to adjust the idle speed with the fast idle screw against the choke quadrant see the diagram below
