Starting Issue Turns Over To Slow ?
25 replies to this topic
#16 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 10 March 2014 - 07:49 PM
Do a volt drop test on the cable front to rear and see whats the reading is.
#17 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 10 March 2014 - 07:51 PM
I checked the voltage at the solenoid and it was basically the same as what the battery voltage is.
Dan
#18 mini13
mini13
  • 3,811 posts
Posted 10 March 2014 - 08:38 PM
ypur doing the right thing so far, just need to go furthur with it,
check voltage across all the cables and earths while cranking, ie
battery earth terminal (actually on the terminal) to the body,
engine  to body
starter terminal to body
starter solenoid terninal to starter motor terminal
also do check battery + to - terminals while cranking, some new batterys are actually pretty crap... halfords own brand for example.
I had an on going issue on the other halfs fiat, occasionally it would not start as iff the battery was dead, jump it and it would be fine for a while.... repeat.... turns out it was just a crappy connection between the battery terminal and clamp, looked fine though!
#19 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 10 March 2014 - 09:06 PM
Do some volt drop tests on the whole circuit http://www.theminifo...ring-volt-drop/
#20 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 11 March 2014 - 07:01 AM
Oh right, it's just that this below is on the Minispares web site for replacement solenoids.
The activation of the starter motor starts with the key (or push button in the early cars), but the most important function is carried out by the solenoid. The current used by the starter motor as it cranks on the engine is very high and the function of the solenoid is to act as a very heavy duty switch. The key or pushbutton is very low current and only sends a voltage to the solenoid that turns on the real voltage to the starter. The solenoid is mounted in the engine compartment and typically either works or doesn't. But we have often seen that the high current part of the solenoid begins to draw too much current internally and thus robs the needed current to the starter. The starter thus doesn't turn fast enough! Cooper S variants had the solenoid in a 12 o clock position and the mini, plus coopers is in the 12.10 position.
Which has got to be the biggest load of old rubbish I have ever read. Where I live, we say "jangan asal omong" or don't talk for the sake of talking.
#21 Stu.
Stu.
  • 912 posts
Posted 11 March 2014 - 07:55 AM
Well I'm not talking, I'm just quoting  :proud:
#22 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
Posted 11 March 2014 - 01:25 PM
 I'm talking about the mnispares website "advice"....and there's not a lot of point in quoting that :-)
#23 ucchockey
ucchockey
  • 158 posts
Posted 10 June 2014 - 05:57 PM
Halfords batteries are made by Yuasa and are very high quality. Yuasa make a vast number of OE batteries and have a tiny failure rate.
#24 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 10 June 2014 - 06:13 PM
Bit a throwback haha cars all sorted now :)
#25 silve1999
silve1999
  • 1,146 posts
  • Local Club: MiniFreakz, Brighton Mini Club
Posted 12 June 2014 - 12:24 PM
Where was the problem?
#26 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 12 June 2014 - 12:41 PM
The terminal on the battery was knackered had to change it.
Dan
