Posted 13 March 2014 - 07:00 PM
Posted 13 March 2014 - 07:14 PM
Choke cable on a DCOE is seperate and attaches to the choke lever, standard mini choke cable works fine
Posted 13 March 2014 - 07:23 PM
Posted 13 March 2014 - 07:37 PM
no there is a pinch nipple on the front of the DCOE to feed the choke cable through - note some people remove the cold start mech (choke mech in old money) so yours may be missing
Item 42 shows the choke lever - http://www.webcon.co...r/40dcoe.htm#42
item 73 is the choke clamp
Edited by The Principal, 13 March 2014 - 07:37 PM.
Posted 13 March 2014 - 07:44 PM
Posted 14 March 2014 - 10:01 PM
Don't bother with the cold start mechanism (Choke) Most people running a DCOE don't use them at all, as they tend to foul the plugs instantly.
The car will start fine you just need to baby it for a coupe of minutes on the first start of the day.
Posted 14 March 2014 - 10:15 PM
Posted 15 March 2014 - 08:53 AM
Posted 15 March 2014 - 09:23 AM
What Size Are These Main And Big End Bearings?Started by scottyboy805 , 19 Jul 2025 ![]() |
Spi Bad Idle And 'tapping' Engine SoundStarted by Simmi Westo , 15 Jul 2025 ![]() |
![]() Help! Water In Oil Question....Started by TerryLee , 06 Jul 2025 ![]() |
