Posted 13 March 2014 - 07:00 PM
Posted 13 March 2014 - 07:14 PM
Choke cable on a DCOE is seperate and attaches to the choke lever, standard mini choke cable works fine
Posted 13 March 2014 - 07:23 PM
Posted 13 March 2014 - 07:37 PM
no there is a pinch nipple on the front of the DCOE to feed the choke cable through - note some people remove the cold start mech (choke mech in old money) so yours may be missing
Item 42 shows the choke lever - http://www.webcon.co...r/40dcoe.htm#42
item 73 is the choke clamp
Edited by The Principal, 13 March 2014 - 07:37 PM.
Posted 13 March 2014 - 07:44 PM
Posted 14 March 2014 - 10:01 PM
Don't bother with the cold start mechanism (Choke) Most people running a DCOE don't use them at all, as they tend to foul the plugs instantly.
The car will start fine you just need to baby it for a coupe of minutes on the first start of the day.
Posted 14 March 2014 - 10:15 PM
Posted 15 March 2014 - 08:53 AM
Posted 15 March 2014 - 09:23 AM
Mini Technical Sections →
Problems, Questions and Technical →
Crank Damper For Ribbed Belt PulleyStarted by BaronVonchesto , 01 May 2024 engine |
Tapping Noise At IdleStarted by Sterling M , 27 Apr 2024 engine |
Piston Rings - A-Series 998 Engine - Help RequiredStarted by WanaGo , 18 Apr 2024 engine |
Exhaust Choice 45Dcoe - Rc40?Started by lachlan1275gt , 13 Apr 2024 engine |
1071 Main Bearing Caps.Started by 246jaenick , 02 Apr 2024 engine |
