Timing Chain Sprockets Dot To Dot Query.
Posted 15 March 2014 - 05:58 PM
The car was running fine before I started work to renew the timing chain, and have not moved the dizzy at all.
I'm in the process of replacing the rattly simplex timing chain with a new standard duplex kit.
I've set the engine to tdc and have removed the timing cover etc. I quickly noticed that the crankshaft woodruf keyway is at the 12 o clock position but the camshaft woodruf keyway is at around 8 o clock and the timing dot on the camshaft sprocket is not lined up with the crankshaft and is180 degrees out on the opposite side.
I know you think I might have tdc 180 out but I've checked this and confirm that the rockers are loose on number 1 cylinder (closest to the rad) and the pully marks lined up before I removed the pully and cover.
I assume the engine is correctly set at tdc as the dizzy arm is pointing at number 1 ht lead (closest to the rad). If this is not right I'm stupid and clearly have it 180 out but I could do with some help as I don't want to go any further until I can get some advice from you guys.
Obviously if I remove the old chain and sprockets as they are I won't be able to line up the new ones using the dots as the camshaft keyway is 180 degrees out.
Thank you very much in advance.
Posted 15 March 2014 - 06:28 PM
Id say your TDC is 180 out
You could turn the engine over by hand, watching the rockers to see the inlet and exhaust opening to work out which stroke your on etc and find the correct TDC.
Posted 15 March 2014 - 07:26 PM
As I said in this position the camshaft woodruf keyway is not at 2 o clock but at 8 o clock.
Are you saying that the camshaft is not timed properly with the crankshaft making it 180 degrees out, and the dizzy has been set in the wrong place to suit the firing order ? I'm not sure because at tdc the far right rockers are loose which I thought was right for confirming tdc.
When I align the dots and get the cam and crankshaft keyways correct, the rockers on the far left are loose.
If that was so wouldn't the rotor arm be pointing at 9 o clock at tdc ?
Sorry if I'm being dumb but I'm trying to understand why this is and how I can correct it withought screwing up the timing.
Posted 15 March 2014 - 07:32 PM
Crankshaft key is at 12 o clock. Camshaft around 2 o clock position.
Timing gears should fit in that position and line up dot to dot. I use a straight steel rule across the centre of the crank hole and the camshaft.
Id be tempted to remove everything and start from scratch to ensure its done correctly. Once you have identified true top dead centre on intake stroke, then fit timing chain etc, then refit dizzy drive ensuring its in the correct way (the connection to dizzy is offset, so it can be 180deg out.). Refit dizzy and set ignition timing.
Posted 15 March 2014 - 07:47 PM
I understand the dizzy offset and thanks for the reminder !
Posted 15 March 2014 - 08:07 PM
Posted 15 March 2014 - 08:38 PM
I'm perhaps worrying too much about trying to fit the new chain and sprockets dot to dot as the Haynes Manual informs. I guess as the engine was running fine before I should just fit the new ones the same way the old ones come off, making sure as you say that the dots and shafts line up.
I hate to be a pest, but can you give me info on what the rockers closest to the radiator should be doing at tdc on ignition timing then. I've seen other posts that say at tdc the rockers should be loose when you wiggle them. (for want of a better word).
Posted 15 March 2014 - 08:52 PM
You're not being a pest, questions are what this place is for. Everyone has to do something for the first time once.
Posted 15 March 2014 - 09:12 PM
Posted 15 March 2014 - 09:25 PM
No confusion, both are the same. Haynes there is talking about ignition timing. It is saying to do ignition timing when the rockers on 1 are loose and the rockers on 4 are loaded (or on the rock). This is also what I have said above and is the position you are in. Cam timing should be done with these two reversed, cylinder 1 rockers loaded (rocking) and cylinder 4 rockers loose. A rocker is described as rocking when it is doing it's job and operating the valve, not when it's slack. This is easily confused though.
Posted 15 March 2014 - 09:47 PM
So I'm dealing with ignition timing then. That would confirm that I have correctly set tdc for changing the timing chain.
I'll fit the new sprockets and chain in the same position the old ones come off as you suggested.
Out of interest, do you know why the cam shaft keyway would be in the position mine is in, ie at 8 o clock and not 2 o clock ?
Appreciate your help, thanks!
Posted 15 March 2014 - 09:52 PM
Posted 15 March 2014 - 10:14 PM
Posted 15 March 2014 - 10:32 PM
Posted 15 March 2014 - 10:44 PM
To confuse this even more.... when the cam in installed and aligned dot-to-dot, yes... piston #1 is at TDC but NOT on it's firing stroke. When the sprockets are aligned dot-to-dot, it is piston #4 that is at TDC on its firing stroke. This confused me the first time I fit a new timing chain and it confuses almost everyone the first time they do this procedure and then start looking at ignition timing.
As Dan said, ignition timing is different than cam timing. When you are looking for TDC to set your timing, you want the points to just open at the specified static timing mark when piston #1 is slightly before TDC on its firing stroke. The rocker arms above piston #1 will be "loose" at that point. The rocker arms for piston #4 will be "rocking" but tight as the valve springs will be compressed.
Facebook (1)
