Was about to buy a clarke, hydraulic engine lift but I am concerned if it will fit between the wheels
What do you guy use engine lift wise
Posted 23 March 2014 - 10:35 AM
Posted 23 March 2014 - 10:50 AM
Posted 23 March 2014 - 10:52 AM
yes it will fit, only you may have to jack the car up, if its to low to get it under the car
Posted 23 March 2014 - 03:04 PM
An electric winch mounted in the rafters of the garage.
Posted 23 March 2014 - 03:08 PM
Is a recipe for disaster unless you are sure a rafter of a garage can support a weight in excess of 150kg.
I personally wouldn't trust it.
Posted 23 March 2014 - 03:29 PM
Got a manual engine lift thing myself, on rollers on the beam in my garage and it works just fine - my beam is rated at something insane like 3 tonnes though so there's that...
Posted 23 March 2014 - 05:09 PM
If your rafters aren't able to handle 150 odd KG then I'd be a bit worried.
Posted 23 March 2014 - 05:12 PM
+1 I have used hoists before with no problems, but I do always make sure to use metal spreader plates on the joist.Is a recipe for disaster unless you are sure a rafter of a garage can support a weight in excess of 150kg.
