Ultrasonic Carb Cleaning
Posted 24 March 2014 - 12:56 PM
Posted 24 March 2014 - 01:09 PM
We'd ask you to register as a trader, I'll send you the details via PM.
Can you offer this as a posted service, or are you only looking to do this in your local area?
Posted 24 March 2014 - 04:44 PM
Posted 24 March 2014 - 04:48 PM
If the carb is stripped will you put jets etc through?
I'll pm you the trader stuff when i'm on my laptop later
Posted 24 March 2014 - 05:15 PM
This doesnt mean you will pay any more but i like things to be 100% , just might delay it a touch.
Seeing as im new here and nobody knows me here is my ebay feedback
http://feedback.ebay...430.m2531.l4585
Edited by Covert, 24 March 2014 - 05:15 PM.
Posted 24 March 2014 - 05:42 PM
Is it only carbs you can do or would the SPI injector be able to be cleaned this way, as i was recommended to have mine cleaned when i took it off the road due to a fueling issue which i have hopefully solved, if when i start it up again (hopefully this weekend!) and it isn't 100% then it may be worth doing if it is possible?
Posted 24 March 2014 - 05:56 PM
Would definitely be interested, broke down again last night due to fuelling issues!
Posted 24 March 2014 - 06:03 PM
Sorry you would have to run injectors through a specialist injector cleaner that way they can be flow tested against manufacturers specificationsIs it only carbs you can do or would the SPI injector be able to be cleaned this way, as i was recommended to have mine cleaned when i took it off the road due to a fueling issue which i have hopefully solved, if when i start it up again (hopefully this weekend!) and it isn't 100% then it may be worth doing if it is possible?
Posted 24 March 2014 - 06:48 PM
Okay, i did wonder when i saw the way it was done if they could actually be done due to the wire connected to the injector, thankyou anyway :)
Posted 24 March 2014 - 09:08 PM
I'll be in touch next week.
Posted 09 April 2014 - 04:04 PM
Posted 21 April 2014 - 08:42 PM
you would be looking at £25 for the whole lot plus postage.
Cheers mark
