MK4 GT TDI Golf Estate. LOADS of room, well built, 50mpg easily and with a remap, high performance too. Its what Im away to buy......
What Daily Driver For £5K
#16
Posted 27 March 2014 - 09:33 AM
#17
Posted 27 March 2014 - 09:34 AM
I think if you get the Coupe they might, but for the saloon they don't?
There are a few decent cars I like the look of, and I had an old E36 BMW for a short time that drove beautifully. However, I just tend to buy cars under £1000. I have been lucky so far and had no major repairs but the cars are cheap enough that it doesn't really matter too much. For me, anywhere between 5 and 10k is the middle ground that I don't want to spend.
I think a MINI or a VW Van are the only two I would actually spend around 5k on. Are you any closer to deciding yet?
#18
Posted 27 March 2014 - 10:26 AM
The 3 series BMW I found cramped. My two lift share work mates both had 330ds. Nice car, went well but felt tiny inside. Both of them had over 170k on the clock. The only thing with them was come winter time and snow was stay at home.
Soda will do but remember they share the same platform as VW and engines as well. So any issues the VW has they will as well. DMF is one of them, when they go it's not a cheap fix. As my son can tell you now..
#19
Posted 27 March 2014 - 10:38 AM
#20
Posted 27 March 2014 - 12:32 PM
#21
Posted 08 April 2014 - 07:40 PM
My issue is I need to buy from a garage as I'm buying using credit card if also fancy the highline range
Edited by Carvell, 08 April 2014 - 08:00 PM.
#22
Posted 08 April 2014 - 07:52 PM
Yes VW PD engines rock!
#23
Posted 15 April 2014 - 08:39 PM
Went to see the Bora but it was sodden inside. Tomorrow I'm off to to see two passat's
http://www.ebay.co.u...984.m1423.l2648
http://www.autotrade...age/2?logcode=p
#24
Posted 17 April 2014 - 04:13 PM
Well, bought this http://www.ebay.co.u...984.m1423.l2648
Had to take it back today under warranty due to o/s rear brake binding, cv joint making a noise and a slight oil leak. Not a great start but its lovely to drive. Great recommendations on the engine people!
Excited to get it back.
In a strange turn of event the courtesy car I have while the Passat is being fixed is my old car. Feels a bit weird!
#25
Posted 17 April 2014 - 04:26 PM
Nice car. Just make sure the correct oil is used for the engine. Also keep a eye out for debris blocking the drain under the battery tray. Yours is a later model like mine was so it will have been modified but worth keeping an eye on it. If it blocks it will cause serious damage to the servo.
If it starts to use coolant dont panic as it could well be the botton right radiator pipe connector. These are known to crack and leak which will need a new rad.
#26
Posted 17 April 2014 - 06:45 PM
Blimy! For that money, i would have one. So cheap!!
Ben
#27
Posted 17 April 2014 - 11:44 PM
