Im building a new engine, as I blew my old 1100 up this is just a tempary engine, this is the spec:
998 head, port and polished.
998 block.
flat top omega pistons.
strengthened con rods.
1100 gear box.
cross pin diff. (if i can afford it!)
new ingition system.
stage 1 kit.
2 core rad.
double valve springs.
What will the 998 be like with the 1098 gear box?
998 on a 1098 gear box.
Bam
, Jun 09 2006 08:43 AM
5 replies to this topic
Posted 09 June 2006 - 08:43 AM
Posted 09 June 2006 - 11:20 AM
well the only fifferance will be the final drive ratio.
It'll be fine if that's what you are asking
Posted 09 June 2006 - 11:50 AM
The gearbox would be able to manage and put the power down better
Posted 09 June 2006 - 12:57 PM
got some in-expensive x-pins at the mo if interested, do one for 120
Posted 09 June 2006 - 03:02 PM
I might be intrested, what make is it, are they new?
