Axle stand alternatives?
Posted 09 June 2006 - 04:32 PM
Are axle stands essential in a strip down? Could i not just prop something solid under there instead? it seems a bit odd paying out for something that doesn't seem to have any obvious benefit over.... well, bricks. I'm a bit strapped for cash,so trying to cut the flab wherever i can.
Also, if i do need them, do i need four or two? I know stupid question, but they only seem to be sold in pairs. Again, purse strings!
Thanks!
Posted 09 June 2006 - 05:11 PM
Posted 09 June 2006 - 05:32 PM
Posted 09 June 2006 - 05:56 PM
Posted 09 June 2006 - 06:55 PM
Posted 09 June 2006 - 07:40 PM
Posted 09 June 2006 - 07:52 PM
Posted 09 June 2006 - 08:32 PM
Posted 09 June 2006 - 08:38 PM
Posted 09 June 2006 - 08:52 PM
i dont know about anyone else but ive never tried driving me mini wile DEAD could be a tadge difficulti must be the bodge mans as i'm using sleepers (the stuff that goes under the railways) and some breeze blocks! though i am thinking of investing in a decent set of axle stands......
Posted 09 June 2006 - 08:59 PM
Back after a long time away (no I wasn't in jail).
Sleepers (as in the old railway kind) or other chunky bits of wood work for me. DON'T use bricks or blocks they can (and do) crack or crumble (with little or no warning).
Ideally all four should be matched but normally it isn't crucial if you use different stands font-to-rear but both the front ones should be a matched pair and the rear ones a matched pair.
HTH
Posted 09 June 2006 - 10:06 PM
If you are just going to be supporting the weight of the shell, then I can really reccomend a trolley. Not a shopping trolley, but you know the sort of thing that the stackers around Tescos annoy you with...? Chop all the sides off, and put the shell on that. It makes it really easy to manouver if you have limited space. If you talk with your local supermarket manager, they may be able to help out with an old one. (I was lucky getting one, and if you aren't starting for a couple of weeks(ish!), you can have mine! If you're close... and have a big estate car!
However, even then, a pair of axle stands are very handy when you take out the subframes. It gives you some "fixed" parts to manouver things around.
Posted 09 June 2006 - 10:39 PM
Yeti
PS thinking about it...... it may of been a dumb idea, get axil stands, they come in usefull, look in the local free ads, once you have finished with them, clean em and sell em on for what you paid....
Posted 10 June 2006 - 12:02 AM
Posted 10 June 2006 - 12:08 AM
Hello my cheeky chappys!
who you calling cheeky.
*leeers meancingly.*
