Spi To Carb Loom Issue
electrical engine
#1 Rover_Mini_Cooper
Rover_Mini_Cooper
  • 26 posts
  • Local Club: oldham & District.
Posted 01 April 2014 - 07:35 PM
Hey Guys!
As the title states, I am trying to source information on how to re-wire an SPi loom to fit a Carb engine.
now before anybody starts saying "use the search button".. i have... endlessly & there are many threads about this topic, but none that specify the points which need to be completed in a clear manor.
The story goes:
I've had an SPi since 2009. ive had endless issues with the injection system. to overcome the issues i sourced a Morespeed 1340 online. I've taken the SPi block out and replaced it with the carb engine, along with all the auxiliaries that come with a carb mini such a the starter motor and fuel system. when i purchased the 1340, the loom was beyond repair, so my only option is to rewire my current SPi loom (due to a new carb loom being close to £200)
i have looked on many many threads, and i am yet to source one that has a bullet point list of what needs doing.
I am hoping this thread not only helps me, but anyone else hoping to do this conversion in the future.
#2 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 02 April 2014 - 05:18 AM
With care you will find that you can strip out the ECU wiring with moderate ease from the main wiring - just a couple of points, the fuel pump is controlled by the relay module, the starter also gets a supply from the relay module, and the temp sender parses it's signal via the ECU.
Apart from those little points it's ease to strip out the fuel injection stuff.
#3 Rover_Mini_Cooper
Rover_Mini_Cooper
  • 26 posts
Posted 02 April 2014 - 07:54 AM
Thanks man!
As far as tge fuel pump is concerned, I replaced it kr a mechanical olong with everything else, its NOT a spi conversion, its literally ising an SPi shell with Catb engine and auxiliaries :)
#4 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
Posted 02 April 2014 - 01:13 PM
Just the temp sender you need to look for - find the wire that come out of the ECU to the gauge and extend it to the new sender - the ECU controls the gauge by PWM based on the analogue signal that comes in from the sender.
It's actually a quit satisfying job - sit on the floor and strip back all the ECU look stuff from the standard loom.
