These fellas:
Also, is it possible to ID My dizzy from this shot? I wouldn't suppose it is so how do I ID it? All we know is it's a Lucas on a 1275 A+ block.
Best Answer KernowCooper , 04 April 2014 - 06:12 PM
Picture one does show a module on the side with the factory connection at the top its a 65D4M which is the factory O.E Equipment Electronic Distributor from about 1990 on.
Go to the full postPosted 02 April 2014 - 09:15 PM
Edited by cal844, 02 April 2014 - 09:16 PM.
Posted 02 April 2014 - 09:17 PM
Posted 02 April 2014 - 09:59 PM
We can... But we need more info
What year is the car/engine
Is there a black box on the side of the dizzy??
With the screw cap I think it is a 65DM4
Screws normally come with new caps - not sure on their size
Posted 03 April 2014 - 06:13 AM
Posted 03 April 2014 - 06:30 AM
I think that is a "side entry" cap, for a 45D Dizzy, and I think the screws are captive in the cap?
Edited by L400RAS, 03 April 2014 - 06:30 AM.
Posted 03 April 2014 - 07:40 AM
Posted 03 April 2014 - 08:24 AM
Cunning plan....take it off and measure it....could be BA thread or metric
Posted 03 April 2014 - 10:28 AM
Edited by Mini Manannán, 03 April 2014 - 10:30 AM.
Posted 03 April 2014 - 05:23 PM
The 45d Distributor body is not normally drilled and tapped for a screw on cap? standard they use spring clips. The same for the 59D and even the ducellier had clips standard. the only one i have seen is the same as Graeme said, the 65D4M which had the module on the side from about 1990 on the A+? odd one?
Can you get a better picture ? maybe with the cap off.
Edited by KernowCooper, 03 April 2014 - 05:25 PM.
Posted 03 April 2014 - 09:34 PM
Will do, I'll get a better pic tomorrow.
Posted 04 April 2014 - 06:12 PM Best Answer
Posted 04 April 2014 - 06:31 PM
Posted 04 April 2014 - 07:01 PM
