Car Just Doesn't Want To Fire
electrical engine
3 replies to this topic
#1 md7708
md7708
  • 79 posts
Posted 05 April 2014 - 11:50 AM
Hello,
My Mini's sick and i feel like I'm going round in circles it all started a few weeks back,
all of a sudden the car just cranked really slow so i figured battery as it gets use but not a lot (at the min)
so i tried jumpstarting it with my magic yellow box and it worked once i got stuck in a car park :/ managed to bump start is when i got home i
switched my C2 battery over problem but persisted :(
so not the battery then.
then i proceeded to test the starter by getting a screw driver (with a plastic handle) and joining the permanent live with the switched live, seemed to work ok
tried to start the car and boom it worked went for a little drive came back left it for a little bit and again it started :) went round my friends came back, no problems.
BUT then come to fit my newly acquired brake conversion this morning and bang back to square one slowly turning over :/ ahhhhhhh
is there any where else i should be checking am i just being blind
could it be that the starter is just past its best?
#2 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 05 April 2014 - 12:23 PM
hmm im not professional so dont take my word for it. Is it running lean? what are the earths like from the engine to the car?
#3 md7708
md7708
  • 79 posts
Posted 05 April 2014 - 12:47 PM
the fuelling is /should be fine (just set it up) and when it decides it wants to crank fast/normally it fires
the earths seem to be ok just from a quick visual, when it stops raining i'm going to whip them off and scrub them up see if that does anything.
just wasn't sure if i was missing something obvious haha or if somebody has had the same happen
i hate electrics
#4 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 05 April 2014 - 01:02 PM
im no expert im sure one will be along soon i just thought id give you something to check :)
Also tagged with one or more of these keywords: electrical, engine
