Jacking Points For Lowering Front Subframe
Best Answer Tamworthbay , 10 April 2014 - 07:28 PM
Jack up on the subframe, then support the weight of the car on a big piece of timber (scaffold board is ideal) across the floor with an axle stand at each end. Make sure its far enough back to get the rear front subframe mounts off. Go to the full post
9 replies to this topic
#1 Fossy313
Fossy313
  • 583 posts
  • Local Club: Mini Club Jersey
Posted 10 April 2014 - 07:24 PM
Hi guys I'm looking at replacing the steering rack and normally for any of my mini work I jack off the subframe but I can't in this being as though I have to lower the SF to get the rack in.
Where the hell do I jack, my floor has been weakened in the last through in appropriate jacking (previous owner) and I'm a bit scared of where to jack, I guess its a case of jacking with a long bit of wood to spread the weight, however with this I'm planning on using axle stands and want to know what thickness and what wood to allow me the maximum movement under the car. (Pictures would be a godsend)
Craig
#2 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 10 April 2014 - 07:28 PM   Best Answer
#3 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 10 April 2014 - 07:29 PM
Has your floor been replaced?? If not id just lift the shell over the subby
#4 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,078 posts
Posted 10 April 2014 - 07:36 PM
Like above put plank of wood across the floor, watch out for the brake pipes and that though.
#5 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 10 April 2014 - 07:39 PM
As above. Then use trolley jack(s) to support the subframe whilst you undo the bolts and mounts. Then lower down using the jacks to give room to get the steering rack out.
#6 Fossy313
Fossy313
  • 583 posts
Posted 10 April 2014 - 07:43 PM
Cheers guys much appreciated, so it doesn't actually matter where I put the peace of wood across the floor? Just staying clear of the brake lines etc and enough room to get the subframe down?
#7 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 10 April 2014 - 07:47 PM
I used abit of wood with some cut outs to clear the battery cable, brake pipe and fuel pipe. I used it quite far forward as there seems to be more rigidity there. Depends on the wood, a large surface area will help spread the weight and prevent any damage to the floor.
You only need the subframe down a couple of inches. Dont forget to undo the engine steadies to bulkhead and possibly the clutch slave to prevent the hose stretching.
#8 Fossy313
Fossy313
  • 583 posts
Posted 10 April 2014 - 08:09 PM
Ok mate much appreciated for the help, as you can gather, first time :), but you have to start somewhere!
#9 tiger99
tiger99
  • 8,584 posts
Posted 10 April 2014 - 11:01 PM
Keep the wood as far forward as possible. The joint between toeboard and floor is very stiff. If it is a rubber mounted subframe (even if you have fitted a solid mount kit, which I recommend) the plank will still clear the subframe mounts. Not so easy with an original solid mounted subframe, you have to go slightly further back.
You will want to remove the exhaust first, as it will foul your piece of wood.
#10 Fossy313
Fossy313
  • 583 posts
Posted 11 April 2014 - 07:16 AM
Cheers tiger, I was planning on removing the exhaust anyway :)
