Electronic Ignition Kit - Engine Wont Fire
electrical engine
#1 Jcoxall
Jcoxall
  • 42 posts
  • Local Club: norfolk mini owner club
Posted 11 April 2014 - 10:48 AM
Hi everyone,
Yesterday I fitted the electronic ignition kit to my 1977 Mini 850, connected all the wires in the appropriate places and it doesn't seem to fire...
Checked for a spark, which there isn't...
I've read that my ignition may be a ballast one and that the red wire from the ignition kit needs to go to the white wire on the fuse box...??
I'll let the pictures tell the rest...
10168440_763341537018881_1287421145_n.jp
10250911_763341810352187_1634384939_n.jp
10253297_763341900352178_1713843935_n.jp
10168536_763341990352169_1870923264_n.jp
10250949_763341967018838_1669435376_n.jp
Any suggestions would really helpful!!
Jack.
Edit - The wire in the last picture wasn't connected to anything before hand...
Edited by Jcoxall, 11 April 2014 - 10:51 AM.
#2 Gremlin
Gremlin
  • 2,142 posts
Posted 11 April 2014 - 10:57 AM
You should have A wire coming from the ignition key to the coil +, and the black wire coming from the distributor going to coil -, and the distributor red wire going to coil + as well
#3 Jcoxall
Jcoxall
  • 42 posts
Posted 11 April 2014 - 11:34 AM
I put the wire that has the tape round it on the coil + because that was going up the loom to the fuse box (top left fuse, which i think is the ignition fuse...) but It was originally on the - terminal on the coil....
So i ran a wire from the ignition terminal on the fuse box straight to the coil +, but I'm still not getting a spark...
The car ran before I put the electronic ignition kit in... (on points)
#4 Gremlin
Gremlin
  • 2,142 posts
Posted 11 April 2014 - 02:39 PM
If it was running fine before the only change you have to do wiring wise is connect the red from the distributor to the coil + and connect the short black wire coming out of the distributor to the wire that goes to the coil -
#5 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 11 April 2014 - 02:53 PM
Is that an accuspark/ powerspark unit? The reason I ask is that a few people on here (myself included) have had problems with the separate trigger wheel. Once I changed to the integrated trigger/ rotor it worked perfectly. It nearly did my nut in as I knew it was in right and even sent the unit back to be checked.
