What Sort Of Speed Should I Be Getting?
#16
Posted 13 April 2014 - 10:07 AM
The air filter is the type that surrounds the dash pot and I have opened this up and looks pretty clean but I am pretty new to all this so I could be wrong
#17
Posted 13 April 2014 - 10:48 AM
If you have a strobe it may be worth also checking the advance up through the whole rev range. Setting it a la Haynes is great: provided the dizzy gives the intended advance curve. It could be sticking or the wrong one for your engine.
#18
Posted 13 April 2014 - 11:04 AM
All the above advice is good, i.e. ensure that it is tuned properly. 60 is disappointingly low, my City E would cruise at 80 all day, with a 2.95 FDR. However, when the transmission blew up spectacularly, and I went to an outfit run by an insurance company, a long time ago (near Tolpits Lane, Watford, I don't know if they are still there) to get a complete power unit, the car ended up accelerating like a rocket, and topping out at 60. The problem was that the FDR was completely wrong. I put my City E carb, manifold and distributor on it, so it should have been identical to what I had replaced, but it wasn't. It came with a twin port exhaust manifold, so it was from a Metro, and although it turned out to be a very good engine, I had to change the FDR and speedo drive gears (all done in situ, somewhat of a struggle) to restore the proper top speed, and, of course, economy.
So I think you need to check your FDR as first priority. Have you a tacho, and what does it read when doing 60 in 4th gear?
#19
Posted 13 April 2014 - 11:05 AM
#20
Posted 13 April 2014 - 11:10 AM
You really don't need a mechanic, just a friend with a reliable car you can compare speed & mileage readings with along a stretch of road. Hooking up a rev counter, even temporarily, will be a bonus.
#21
Posted 13 April 2014 - 11:12 AM
#22
Posted 13 April 2014 - 11:28 AM
I really don't think it's something where a mechanic can contribute a lot, it's likely to just need time to go through some relatively simple checks.
Confirm the final drive ratio
Look for mechanical drag: brakes, tyres....
Look at induction basics: blocked filter & air leaks
Check the ignition: being able to swap out some parts would be handy.
Look at the fuelling.
#23
Posted 13 April 2014 - 11:32 AM
#24
Posted 13 April 2014 - 11:34 AM
Ok, so here's the problem, you lost me at 'confirm the final drive ratio'. I wouldn't even know how lol
Do you have a rev counter?
#25
Posted 13 April 2014 - 11:36 AM
Yes I do
#26
Posted 13 April 2014 - 11:37 AM
Yes I do
Excellent.
If you've got a sat nav go out, and see how many revs the engine is doing at 60mph on the sat nav.
Then come back and post it and we'll work it out.
Also, what speed the speedo is reading when the sat nav says 60mph
#27
Posted 13 April 2014 - 11:42 AM
Yes I do
Excellent.
Ok great, thanks
Won't be until later, need to adjust valve clearances and can't do that whilst I have an 18 month old clinging to my leg ;)
#28
Posted 13 April 2014 - 11:43 AM
Yes I do
Excellent.
Ok great, thanks
Don't worry mate, those small hands will be great for when you drop something into an inaccessible area of the car, probably a spanner, or a bolt
#29
Posted 13 April 2014 - 12:02 PM
is it wrong to suggest that that is the reason we had him? ;)
Ok great, thanks
Yes I do
Excellent.
#30
Posted 13 April 2014 - 12:08 PM
is it wrong to suggest that that is the reason we had him? ;)Ok great, thanksYes I doOk, so here's the problem, you lost me at 'confirm the final drive ratio'. I wouldn't even know how lol
Excellent.
No!!
